Having Clutch Problems
I have been having clutch issues for quite a while.
Have an aluminum flywheel, and ACT clutch disc and pressure plate. Can't seem to find the right adjustment. One drive it will be slipping, next with just a slight adjustment, and the gears will grind. Seems no matter which way I go I cannot find a sweet spot. Got any suggestions ? |
Try making multiple fine adjustments on it. IE: go out and add or lose 1/8'th of a turn at a time..etc Also the clutch adjustment is in the FSM.
Fsm ?
| All times are GMT -7. The time now is 02:08 AM. |
