fuel pump relay issues.
Old Oct 4, 2010 | 11:05 PM
ok, so the PO of my sisters TT killed the FPCU and hard wired the fuel pump to be at 100% whenever the ignition is on. No big deal, so I replace the two wires that where cut, plug a known working FPCU out of a q45 (same as the TT) and I got nothing. So I traced it down to the relay, everything works when I ground out the relay, so I go to the ECU pin for the relay and ground it out there and it works. Is there anything I could have missed that would cause it to not ground?
Old Oct 5, 2010 | 07:22 AM
skib's Avatar
This facepalm's for you!
sure Q45 is the same?
Old Oct 5, 2010 | 11:04 AM
I have cracked open 12 q45 FPCU's and they are the exact same, down to the coloring of the resistors.
wrenchwench
Apr 6, 2015 03:27 PM
kbowden
Jul 14, 2012 08:15 PM
LVZ280
Aug 8, 2011 06:48 AM
hoov100
Oct 4, 2010 11:05 PM
Loggerboy666
Oct 7, 2003 12:43 AM
