| hoov100 |
Oct 4, 2010 11:05 PM |
fuel pump relay issues.
ok, so the PO of my sisters TT killed the FPCU and hard wired the fuel pump to be at 100% whenever the ignition is on. No big deal, so I replace the two wires that where cut, plug a known working FPCU out of a q45 (same as the TT) and I got nothing. So I traced it down to the relay, everything works when I ground out the relay, so I go to the ECU pin for the relay and ground it out there and it works. Besides the ECU, is there anything I could have missed that would cause it to not ground?
