TwinTurbo.net not helping out situation....
Guest
Posts: n/a
I just had my car checked out from a very relaible mechanic... I have a high idle and is erractic during warm up and sometimes it happens after it seems to be warm.... My idle rests at about 1300 rpm and the mechanic said that ithas something to do with the mass air flow meter according to his cp but that it isnt the MAFM itself.... something possibly like a ground problem possibly he said.... anyone had this problem.....
Re: TwinTurbo.net not helping out situation....
Might be a vacumn leak also, try spraying a bit of carb cleaner around some of the areas in your car. I'm assuming it's a twin turbo.. You'll hear the idle kick up if you have a leak.
Be careful though, as carb cleaner is flammable and you should only do this when your car is cool.
- john
- john
