Factory Alarm Keeps Going Off
Old Jul 29, 2003 | 02:16 PM
Riz Z Speed's Avatar
Administrative Brown Guy
i had the same problem
I just disconnected the damn thing! I couldn't figure out which connector was causing the problem, so I just pulled the whole thing out. In case your interested, the alarm module is located right next to the ECU. Just to the upper right of it. You can either disconnect both harnesses or just take it out altogether. Its a small little box with a big blue relay attached to it. I would just unplug it first. See if your car still starts and runs alright. Some ppl have stated that their car won't after unplugging and others have told me that there is a fuse inside of the box. Not so in my alarm and the little SOB wasn't easy to open either. Hope that helps peace
Old Aug 12, 2003 | 07:20 PM
Ecu is located under the passenger side floorboard. Its under the wood flooring. The Ecu is larger metal box with all the wires coming out of it.
avmanap
Sep 9, 2011 05:06 AM
nismaniac
Feb 22, 2006 11:39 PM
91zxtt
Nov 5, 2004 11:42 PM
bazball
Mar 20, 2003 09:53 AM
WagdogZ
Jun 12, 2001 06:49 AM
