Electrical problems
Old Aug 4, 2005 | 08:34 PM
Jays_Z's Avatar
Electrical problems
Wassup guys I'm pretty new to this forum as a member but has always logged on as a guest. Anyway my dash board warning guages stays on, even with the key out and would stay running without the key. I managed to eliminate the constant running by changing the fuse box, but the lights on the dashboard constantly stay on. so far i checked the ignition switch, relays and fuses and thats not the problem. if anybody can help me out id be very thankful.
Old Aug 4, 2005 | 08:46 PM
v0va's Avatar
Russian Pimp
Does the switch to turn them on work properly maybe when you twist it doesnt really twist enough to turn them off, that sounds like what could of happend, umm
Old Aug 4, 2005 | 08:49 PM
Jays_Z's Avatar
its not the switch i disconnected the switch completly and it still stayed on.
Old Aug 4, 2005 | 08:54 PM
NISMO LMR's Avatar
Wow... The fun of owning a Z32
This is a new problem to me. I've never heard of such a thing occuring. I'm interested to hear what's causing this as much as you are buddy.
Old Aug 4, 2005 | 09:39 PM
91zxtt's Avatar
That is a first. Dash warning lights staying on even with the key out of the ignition. Hmmm.
Did you recently do any electrical work, or did you install different gauges?
Old Aug 6, 2005 | 09:56 AM
Jays_Z's Avatar
I haven't done any recent electrical work.
Old Aug 6, 2005 | 04:19 PM
91zxtt's Avatar
Remove fuses one by one to determine which circuit is giving you problems. Then you get to go on a wild goose chase. I'm guessing that one of the gauge panel wires got pinched along with a constant 12v wire and that's why they're staying lit.
Old Aug 10, 2005 | 01:13 PM
Jays_Z's Avatar
I tried removing the fuses and the relays and still have the same problem.
Old Aug 13, 2005 | 05:26 PM
91zxtt's Avatar
You removed all of the fuses and it still does it? That can't be possible. Everything in that panel is switched 12v. Nothing is constant 12v.
Old Aug 19, 2005 | 08:04 AM
Jays_Z's Avatar
Believe me when i tell you i removed all the fuses and the relays and it still stayed on. There's a plug that goes into the fuse box when I pull the plug out the dashlight comes off.
Old Aug 22, 2005 | 08:25 PM
Jays_Z's Avatar
I fixed my problem, the wires under the relay box were touching each other causing the dashlight to stay on. Thanx guys for all your input.
licketysplit
Feb 4, 2014 08:06 AM
lostdriver
Feb 2, 2014 01:40 PM
Jose Rios
Oct 27, 2012 08:44 AM
c-los.p
Oct 3, 2010 06:22 PM
cerealkilla
Mar 10, 2004 06:47 AM
