bardabe |
07-06-2008 09:19 PM |
EGR delete question yes I searched, kinda need the upper guys help (Zlover, 91zxtt..)
Alright i deleted the EGR in my 91 TT with the 300degree kit. ive done it times before however.... i put the engine back in my car (also did the under plenum water line, carbon canister delete and boost solenoid deletes.) and ehm I kinda forgot to put bolts where the EGR valve bolts up to. :dropjaw: I normally put bolts there. will there be a problem (vacuum / boost leaks) because I didn't put those bolts there? (the ones behind the engine that hold the EGR valve in place)
-Juan
