dos problemos in the belt section
Old Aug 27, 2004 | 10:23 AM
b300z's Avatar
caught the z fever
there have been two strange occurances in the belt area of my engine. the first problem is there is a large bolt sticking out and it is rubbing one of the belts. i noticed it yesterday when my battery went dead and i dont remember it ever being there. it doesnt go in, it doesnt go out.
the second problem is happening somewhere inside that circle that i drew. it is making kind of a scraping or grinding noise, every once in a while, and most of the time when i hit the gas pedal. i noticed this problem this morning. any ideries of what it could be?
Old Aug 27, 2004 | 11:44 AM
91zxtt's Avatar
Is the bad bolt at the pinkish mark you made? If so, it looks likes it's a power steering mount bolt. It probably wasn't tightened all the way when the belts were put back on last. It should thread back in.
With your other problem. Try to pull the wiring harness back and see if there's something rubbing behind the harness. It could be the wiring harness rubbing on the belt.
Old Aug 27, 2004 | 02:20 PM
b300z's Avatar
caught the z fever
yea the bolt is that pink thing, and the white part is where it is rubbing the belt. ill go try and jiggle or push something to see if the bolt will go in cuz i went at it with a ratchet and it didnt go anywhere.
and i think it might be the whole pulley that is rubbing against the cover. its gotten a little off balance since theres only 3 bolts there. theres some scrapings around the pulley too.
Old Aug 27, 2004 | 02:23 PM
CanyonCarver's Avatar
Jack Of All Trades
If zxtt is right about the bolt, it might be out far enough that the pump has turned and is rubbing something that it shouldn't. If the bolt won't turn, loosen the belt first to get the pump out of the bind that it's probably in.
Old Aug 27, 2004 | 05:22 PM
91zxtt's Avatar
What did Zwrecker do when he put that thing back together? Did he give you a warranty on that thing?
Old Aug 27, 2004 | 10:06 PM
b300z's Avatar
caught the z fever
yea i had a warranty on the car until i got out of his driveway. it saved me a lot of money in the long run you know.
i dunno. when he gets back on here id like to find out how that fourth bolt got broken off
Old Aug 29, 2004 | 01:46 AM
Riz Z Speed's Avatar
Administrative Brown Guy
well now i can see why he decided to go with an electric fan setup.
Old Aug 29, 2004 | 10:44 AM
b300z's Avatar
caught the z fever
yea im happy he did that now
otherwise i woulda probably ran over my own alternator
Old Aug 31, 2004 | 09:11 PM
Z_WRECKER's Avatar
Hey i never had a fourth bolt....I think it might have gotten broken off when the timing bolt was changed last, so when i changed the water pump ( seal leaked on the old one) i never out another one in , but it was on my list of things to do, i promise. As far as the bolt goes, all my bolts were tightened fine. It's one of the things that drove me crazy ( belt noise in the winter ), so i would check/change my bolts religiously. I even had that power steering bracket changed ( took parts off my buddys Z ) because the old one was bent. When you had the radiator hoses changed did you guys mess with the belts? I can't imagine it just coming off because they were pretty tight on there. As a matter a fact i checked those things over before you came to get the car.
Old Sep 1, 2004 | 08:09 AM
b300z's Avatar
caught the z fever
i have no clue what happened. i lost the nut for that bolt for the alternator.
and for the bolt for the pulley, do i have to get that exact bolt so that the pulley doesnt go off balance anymore?
my steering is always really tight the first time after i start up my car. is that something that the 300 does? its fine after i turn the wheel for the first time.
Old Sep 1, 2004 | 09:03 AM
Z_WRECKER's Avatar
I had the axle booths changed the day you got the car, so i wouldn't know. I can't say i had that problem.
Old Sep 1, 2004 | 11:52 AM
b300z's Avatar
caught the z fever
it feels like the power steering isnt working until i get to moving through the first turn of the weel, and then its fine. the steering wheel also pulls when i am driving. the tires are worn but i dont think they would be the whole problem
Old Sep 4, 2004 | 01:27 PM
Z_WRECKER's Avatar
Sorry buddy i don't know what it could be....I wish i was the first owner of the car, then i would know everything about it.
dammitmitchell
Site Brainstorming
May 21, 2011 06:40 PM
Outkast
Mar 14, 2006 06:20 PM
CanyonCarver
May 22, 2005 04:56 PM
Spyder Z 15
May 6, 2005 10:47 AM
Riz Z Speed
Feb 4, 2005 09:30 AM
