Compression check on 91TT
Old Aug 2, 2005 | 09:08 PM
refurbit's Avatar
Can someone advise on the proper procedure for checking the compression on each cylinder. Between what ranges is acceptable on the compression gauge.
I've searched the threads without any luck.
Thanks much for your help.
Old Aug 3, 2005 | 07:43 AM
NISMO LMR's Avatar
Well I know how to do so on Honda's... I've never done one on a Z32, but I'm sure the same procedure applies.
-Remove the Fuel Injection Fuse/Main Relay/Anything that will cut the Fuel to the Cylinder
-Remove the plug wire of the Cylinder you wish to test (In this case, Coil Pack)
-Remove the Spark Plug from that Cylinder
-Insert Compression Test Tool and Gauge
-Turn Engine over about 3 times (For this step you'll need another person)
-Obtain a good reading, and check your manual for proper numbers
It's pretty basic. Good luck.
Old Aug 3, 2005 | 09:37 AM
emo236's Avatar
confuzed member
your numbers should be around 150. you should have any variance (whether it be less or more) than 10% of what it should be.
Old Aug 3, 2005 | 09:44 AM
emo236's Avatar
confuzed member
Also, if they're all pretty uniform, meanign the results are close together between cylinders, then that's a good sign.
Old Aug 3, 2005 | 09:56 AM
Riz Z Speed's Avatar
Administrative Brown Guy
full procedure on how to in the FSM.
https://www.zdriver.com/forum/showthread.php?t=9340
Old Aug 3, 2005 | 09:08 PM
91zxtt's Avatar
186 max, 146 minimum with no more than 15 psi variance, if I remember correctly. I just did this 2 weeks ago.
If you remove all 6 coil packs and plugs together, then you don't have to worry about disconnecting the main fuse to prevent the car from starting.
Old Aug 4, 2005 | 05:26 PM
NISMO LMR's Avatar
What about the Fuel being Injected then?
Old Aug 4, 2005 | 09:58 PM
91zxtt's Avatar
Good point. Don't forget to disconnect the fuel pump relay.
Old Aug 5, 2005 | 07:12 AM
refurbit's Avatar
Thanks guys
Old Aug 5, 2005 | 12:50 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
or you can just disconnect the PTU. I wouldn't say 146 is the minimum, and I've never seen on as high as 186. The FSM actually says 172 is the max for a TT, and I'd say anything over 120 is safe (the higher the better, but lower than 120 and I'd recommend a rebuild of some sort), but no more than ~10psi variance between cylinders.
Old Aug 6, 2005 | 04:47 PM
91zxtt's Avatar
Not according to the FSM. I'll agree with you on that TT will be less than 186 since it runs a lower C/R than the N/A, but 120 is too low unless you're ok with a car running under peak performance. FSM states 14 psi max variance. 10 of course would be better.
Old Aug 14, 2012 | 10:40 AM
HKS Z32's Avatar
sorry for bringing this thread back from the dead but what if 2-6 cylinders all show 150 but cylinder # 1 shows 180?
92 tt?
any ideas?
Old Aug 15, 2012 | 01:47 PM
Rupe's Avatar
Horsepower Mathematician
Got one mean cylinder there :P
Thomas Ward
Jun 10, 2014 11:40 AM
Mrmoose
Oct 9, 2010 07:12 PM
domsgarage
Jun 13, 2010 09:53 PM
SPYCARRUSSELL
FS: 300ZX (90-96)
May 12, 2006 09:31 AM
NexGenXVii
FS: 300ZX (90-96)
Dec 13, 2005 09:37 PM
