Clutch.
Ok as u all know I am going through a TT convertion. well I'm wondering what's better a six puck clutch from RPS, or teh Street clutch from JWT?
1 vote RPS
if you're gonna do the clutch, might as well get a new flywheel as well.
consider a lighter driveshaft too since that'll all be apart anyway. I vote RPS clutch & flywheel. |
a 6 puck clutch will have a harsher engagement and will also be louder i think. it will be harder to slip the clutch
a street disc is self explanatory...for normal driving use, uses a stronger pressure plate and go with a lightweight flywheel, stronger clutch pivot ball, stainless steel clutch line, rear main seal, new shifter bushings, and better roller bearing pilot bushing |
Practically a whole clutch kit. right or wrong?
a clutch kit will only include the throw out bearing, clutch disc, and pressure plate.
Originally Posted by rizzspeed
a clutch kit will only include the ..........
and a pilot bushing. You'll have to buy a pilot roller bearing.
