ZDriver.com
-   300ZX (Z32) Performance / Technical (https://www.zdriver.com/forums/300zx-z32-performance-technical-47/)
-   -   Chirping Sound While Driving (https://www.zdriver.com/forums/300zx-z32-performance-technical-47/chirping-sound-while-driving-7695/)
badboyZ2NV Nov 23, 2003 09:44 PM
Whenever i drive my z. I hear chirping sounds coming from the back. i ahve tried to find it, and searched everywhere at the back to fix it and no matter what i do, its the same result..More chirping. It comes from the front to but thats the hood. all i need is Wd-40 and it goes away but only for 1 day or 2...Any suggestions?anyone have similar problems,..please contact me
Riz Z Speed Nov 24, 2003 01:21 PM
To stop the chirping from the hood, you'll have to open it first. Then you'll have to locate two rubber stoppers at either end of the engine bay, right up front at the corners. These stoppers twist up or down. Be careful because depending on the age of your car, these could break.
As far as your squeak/chirping from the back of the car is concerned, keep searching. You'll find it. It sounds like you have a loose interior panel or maybe you have something in the spare tire well that's rubbing against the bare metal or tire that makes noise while you're moving.
Try having someone else drive (I know it's hard to let someone else drive, but give it a chance if you want to fix your problem) while you look for the noise. It might ultimately just be your suspension trying to tell you something. Maybe you're in need of new springs and/or shocks.
Riz Z Speed Nov 24, 2003 01:26 PM
Oops, I forgot. I was gonna include a pic to show the location of the adjustable rubber stoppers.:D
Look for the white arrows just above the headlights.
badboyZ2NV Nov 24, 2003 03:13 PM
I already know about the front 2 rubber stoppers. no matter how many times addjust them. it goes away but then comes back and mi tired of having to keep going under hood everyday just to do that, altho the chirping does piss me off . the back has the same chirping as the front so i know it cant be the suspension or coils...its gotta be something simple i jsut cant seem to find tho..its irritating especially now when my NEW CLUTCH IS GONE!
