Catalytic converter
Old Mar 21, 2013 | 05:30 PM
Rrassi300zx's Avatar
Catalytic converter
Alright zdrivers I just picked up my car had timing belt done, what a difference IN performance, huge improvement in power, i was talking to the mechanic Eric from pons and I asked him if I could take the catalytic converter out, he said that i could and wouldn't have a problem because I have a 1990 and that year the oxygen sensors were not connected to the cats! So now I'm taking them out for sure, just need some feed back from the experts on this forum if this sounds right? How much up would I gain? And would it sound much louder? Thanks for the feedback.
Old Mar 21, 2013 | 06:40 PM
PredatorZ's Avatar
Test Pipe
If you are lucky your cat is flanged on both ends, then all will need is a "test pipe" of the same dimensions as your cat. You might need to have a local muffler shop set you up that way. Then if you need to do emissions you can swap the cat back in.
Old Mar 22, 2013 | 05:39 AM
No emissions test here in Miami Florida so no worries there, so off with that dead weight and welcome the flo. I was looking up some test pipes bought it seems like some regular exhaust tubing will do? I want it to have a nice grount but not too loud, I'm wondering how it would sound?
Thanks Predator.
Old Jun 12, 2013 | 12:02 AM
spank61's Avatar
cats
after i passed smog which involved adding another main cat in line and losing the h pipe, i had the guy cut out the sections with the cats, and put straight pipe on all the wayto the muffler, i was expecting it to be significantly louder, but it is maybe 10 percent louder at idle, i don't think i gained any power, even though the flow rate is greater now, the cats aren't there to heat up the exhaust, harder to push through cold air, it never even gets warm, but it still pulls hard, and when you gas it hard sounds pretty good
pneftali72
Oct 16, 2013 06:36 AM
LVZ280
Apr 12, 2013 12:40 PM
280zxbrandon
Jun 7, 2006 08:25 PM
rayzturbo
Jan 1, 2004 02:16 PM
cm3
Apr 5, 2003 05:40 PM
