Can it be the Alternator?
Old Sep 24, 2006 | 11:24 AM
jtodafullest25's Avatar
Aiight...check it. Back when my engine was running, i had a lil problem. when i was up between 40mpg and up, then i got on the brakes hard the revs would go all the way down and then the engine would cut off. only way i keep this frum happening was throw it into neutral during hard braking. my question is what would cause that??? is it the alternator?
Old Sep 24, 2006 | 12:56 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
Not likely the alternator... it's probably your intake or your IACV (Idle Air Control Valve). What kind of intake do you have?
To solve it (and I'm 99% sure this will do it), do this...
http://www.twinturbo.net/ttnetfaq/FAQpages/stall.html
and raise your idle a little. My car would do it when the idle was set at ~750rpm; since I adjusted to 850, I haven't had the issue.
Old Sep 24, 2006 | 01:17 PM
emo236's Avatar
confuzed member
Are you leaving your car in gear while braking all the way until coming to a stop. Dumb question, but you never know.
Old Sep 24, 2006 | 03:08 PM
he might have an auto^^^ otherwise i will say...."thats dumb"...with you. and uhh....you mean 40mph not 40 mpg correcto? lol
Old Sep 25, 2006 | 04:29 PM
no not all the way to a stop. and i had the stock intake, now im putting on a JWT intake. and yea...."mph"
Old Sep 25, 2006 | 05:18 PM
Clean your throttle bodies and raise your idle a little bit (there's an adjusting screw on the side of it, on the back of the plenum... get a long flathead and go at it from right by the brake master cylinder area).
I'm still sure it's not your alternator... if it were your alternator, your battery light would commonly come on at low rpms. I think your car is just choking for some reason.
Old Sep 27, 2006 | 03:57 PM
i was talking to Cris at ultimate Z...he was telling me the it also could be my mass airflow sensor. he said this cause my lil plastic underbody is kinda f'ed up and could be causing turbulence to the sensor ultimately...engine cut off
Old Sep 27, 2006 | 04:53 PM
... it could... but if your intake is stock, it's highly unlikely that any significant dirt particles have made it to your mass airflow sensor (the stock intake draws air through about 2 feet of tubing before it even reaches a filter). Mass airflow sensor damage is more common in cars with aftermarket high-flowing intakes where the particals can go through the filter directly into the sensor. The stock intake doesn't make it easy for those particles to even reach the filter, let alone the sensor. It's definately worth a look though. (Speaking of sensors, it could be related to the TPS too.)
Are you in Illinois? (I'd gather from speaking with the guys up in Streamwood that you are, but you may have talked to him over the phone, so I figured I'd ask.)
Old Sep 27, 2006 | 05:42 PM
Yes....the TPS!!!....no clue what that is. please explain. on a difrent note. ive read sum where, i belive it was on here about cutting short the intake tubing. good idea of bad?
Im Actually Born and raised n NY. Currently im doin time the army here n oklahoma. kinda sucks except that im close the the Z's of Dallas...gotta make that trip one day
Old Sep 27, 2006 | 05:44 PM
Oh amd congradulation on reaching you 500 post mark. is there sum type of prize? or jus personal goal. I was really wigged out when sumbody on my previous post was striving for 1000
Old Sep 27, 2006 | 05:47 PM
I believe what you read about the intake piping was for eliminating extra tubing on NAs... doesn't apply to you. When you install the JWT Pop Charger, that'll be all the work you have to do with the intake (except for removing all the stock airbox components).
The TPS is the Throttle Position Sensor... it's on the driver's side throttle body. Here's how to test it...
http://www.twinturbo.net/net/viewmsg...orum=technical
Old Sep 27, 2006 | 05:48 PM
ummm we dont really celebrate that...now 1000 you go..cool look 1000...but still no one is to impressed. silverhand has like almost 10,000 posts...now that is an accomplishment...but it also makes since for who he is...the TPS is the Throttle Position Sensor...it can get dirty or missagjusted and the car will run crummy....look it up there are threads write ups what not on the web on how to clean or adjust it...
damn you beat me to it
Old Sep 27, 2006 | 05:54 PM
ne benefits for post count that I know of... 500 is nothing on the grand scheme of things. Let's see....
ChicagoZ.com - 759 posts
300ZXClub.com - 2,109 posts
TwinTurbo.NET - 4,986 posts
Old Sep 27, 2006 | 05:56 PM
you dont love us..... and wow TT.net..... thats the hardcore site right there....i have a name...but i dont dare venture into the posting territory...i just lover there classifieds section.
Old Sep 27, 2006 | 05:59 PM
how long have yall both have yall Z's
Old Sep 27, 2006 | 06:04 PM
This site doesn't get the traffic that 3ZC and TT.NET get, so I don't have a reason to post much on here (not as many questions to answer). Believe it or not, I start threads on here more often than either of those two sites.
I go to TT.NET to be serious - research or help
I go to 3ZC to make fun of idiots, because those people answer questions even when they don't know the answer
I go to ChicagoZ.com and here to help and talk... much more friendly places to be
And for reference, I've been on TT.NET since August of 01, 3ZC since fall of 03, ChicagoZ since spring 04, and here only for a year and a month, so the fact that I have less posts here makes sense.
I've also posted on Boost-World.com, 350ZForum.com, My350Z.com, ZChickz.com, ZCar.com, and even Supraforums.com, VWVortex.com, and Nico Forums (as well as others that I'm sure I've forgotten)... all substantially less though (I only have 35 posts on My350Z.com)
I had my first one for just under 3 years and my current one for a year and a half.
Daniel Coffman
Apr 14, 2013 06:36 PM
koukiAE86
Jan 24, 2008 08:21 AM
MetalTear17
12
Sep 7, 2004 01:42 PM
DoTheDrew888
Aug 26, 2004 08:35 AM
tt300z
Jul 22, 2004 12:06 PM
