A/C Compressor questions.
Old Jul 18, 2010 | 12:10 AM
luis88's Avatar
i was fixing my compressor but lost some parts in the process so now i need to buy one
does anyone know what other car has the same compressor
i found some on ebay but would rather just get it in a junk yard that will take one day instead of waiting about two weeks
my car was built in 10/89 i has the R12 system can i switch to r134?
what would i need to convert it?
its a non turbo 2+2
Old Jul 18, 2010 | 10:56 AM
ZLover4Life's Avatar
Encyclopedic Knowledge
To convert to R134a, you need the R134a compressor (and maybe a new drier) and a vacuum pump to remove all the old R12 and lubricants. Then you'd need the proper oil and R134a, but not before replacing all o-rings (you'll have to do this either way - if your AC system is dead, the o-rings are probably shot).
Why do you think you need a new compressor? Problematic AC systems are usually the result of leaks in the system (or sometimes a worn clutch, which can usually be replaced separately). And an R12 system converted to R134a won't perform as well as a straight up R12 system.
There are alternatives, too... I used "Freeze 12" on my 90 TT without replacing any components at all. It's essentially an R134a compound with additives to make it compatible.
In short, do a LOT of research before making a decision. AC work is difficult and you have to be extremely meticulous to ensure that you don't leave leaks that'll land you right back where you started.
Old Jul 22, 2010 | 08:20 PM
luis88's Avatar
i got a used compressor from craigslist now i need to replace my ac line since it got bent and ill keep it r12
itawolf
Apr 9, 2014 04:58 PM
ynotmedic
Mar 27, 2010 06:36 PM
rtmorgan
Sep 3, 2008 12:10 PM
apache21
Jul 13, 2005 04:08 AM
BORICUABOND
Aug 8, 2002 11:29 PM
