Boost Gauge not working..help??
Old Sep 16, 2005 | 06:13 AM
elmacho0326's Avatar
Anyone have any idea why my boost gauge is not working..1993 300ZX TT. I am getting full boost but gauge is usually pinned at 14+ and doesn't move from there except on occassion. Just trying to see if you all know something since Nissan can't seem to figure it out, thanks,
Jon
Old Sep 16, 2005 | 08:12 AM
My FairLady Z32's Avatar
There is a 1/8th inch hose that runs a across the firewall. The hose connects to a tee (left rear of engine) by the waste gate it runs all along the back of the engine compartment and connects on the right side, about where the boost gauge would be. A leak in the hose would explain the partial gauge movement. Make sure it's connected properly and has no leaks. This hose is what the gauge measures from. It's hard to hear over the engine, but if you manually open the throttle plate or have someone press the pedal, you can often hear a pressure leak. But, I hope Nissan would find it, if it's only a leak. Good Luck!
Old Sep 16, 2005 | 08:54 AM
b300z's Avatar
caught the z fever
stock boost gauges are not reliable....get an aftermarket one
Old Sep 16, 2005 | 02:01 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
why does everyone think that every Z32 boost gauge is not reliable? Mine reads EXACTLY what my AVC/R reads. There are exceptions where it won't be accurate, but out of the 2 Twin Turbo's I've had, both of them had accurate stock boost gauges.
Old Sep 16, 2005 | 02:08 PM
I agree. Unless your boosting at 15+ psi, stick with stock!
Old Sep 16, 2005 | 09:23 PM
b300z's Avatar
caught the z fever
ok....sorry
i just said that because others with TTs have mentioned the same
plus i dont even have a TT so i wouldnt really even know
VanBruno
Nov 2, 2014 10:16 PM
Evan Faris
May 19, 2013 01:37 AM
83turbz
Jul 12, 2012 11:27 AM
