ZDriver.com
-   300ZX (Z32) Performance / Technical (https://www.zdriver.com/forums/300zx-z32-performance-technical-47/)
-   -   Blew Something..... (https://www.zdriver.com/forums/300zx-z32-performance-technical-47/blew-something-15071/)
domsgarage Oct 2, 2005 07:08 AM
Blew Something.....
As I was trying to look for the line out on my stereo last night, my friend grabbed at my wires. In so, something blew. It sounded like afuse. And now the radio doesnt work, as well as the dome light. I would think that this would be a fuse. But after checking EVERY SINGLE one. Again, this morning. I cheked these fuses again, and even replaced some of them even though they were not bad.
If it is not a fuew, then what can it be? And how can I fix this? I miss my blast beats. :( :( :( :( :(
bardabe Oct 2, 2005 09:16 AM
a relay maby?
domsgarage Oct 2, 2005 09:26 AM
I was thikning that to maybe. But all of the writing of the labeling on the relay box is scraped off.
ZLover4Life Oct 2, 2005 10:29 AM
check the fuses again, it really has to be a fuse.
top left and top right are the two possible ones. Replace them even if they don't 'look' blown, because I've had 1 or 2 instances where I had blown fuses that didn't look blown, but I knew they had to be so I replaced them and it fixed my problem
http://www.botos.com/david/1990_300ZX_fuse_label.gif
good luck
domsgarage Oct 2, 2005 03:41 PM
I know how to read the fuse box. I replaced many of the ones that It could be.
My interior light is off, the radio is off, air bag light is on, security light does not come on.
If someone can look in the owners manual and tell me what fuse and what relay does what, I would really appreciate it.
Im trying to find out what circuit is connected to all of these. I can easily go replace all of the fuses, but I dont think that is the problem. Someone please help. Thanks.
domsgarage Oct 2, 2005 03:56 PM
I just changed every single fuse. Even the ones I switched out this morning, i changed again. So every fuse in the car and under the hood are good.
Could it be a fusible link??
napoleonzheking Oct 2, 2005 04:45 PM
www.carfiche.com get the FSM for any diagrams and info you may need... hope that helps...
