BrownBomberZ |
04-25-2012 09:56 PM |
Battery/charging system problem
Ok so recently, maybe 4 months ago, I replaced the alternator in my 1990 300zx NA. And a few weeks ago my battery light comes on but it is only half its brightness when I am at a stop, but when I take off and the car moves the light goes away. I had the battery tested and it was fine. And I Have been meaning to remove the alternator to have it tested, but what I was wondering is what else could be causing the light to act this way if it is not the alternator.
I am getting the alternator tested also because some of the power steering fluid has started to leak from the hose and is dripping into the alternator. can this also cause the problem?
Thanks guys for any help you can give
