ZDriver.com
-   300ZX (Z32) Performance / Technical (https://www.zdriver.com/forums/300zx-z32-performance-technical-47/)
-   -   Battery Cable (https://www.zdriver.com/forums/300zx-z32-performance-technical-47/battery-cable-7522/)
tsefreeflow Nov 4, 2003 06:54 PM
Battery Cable
Has anyone replaced the negative terminal on the battery? Mine is just about to break completely off and it looks like it goes into a harness or something. It looks difficult, any ideas?
Riz Z Speed Nov 4, 2003 08:46 PM
you could/should also try one of those grounding rings/kits. You'll be glad you did.
Doesn't the ground cable just go to the block? The first mounting point is directly behind the battery to the body, and from there it should go to the block, I think.
tsefreeflow Nov 5, 2003 07:32 AM
Yeah, I did figure it out, The wire broke off from the battery terminal and the connection point right behind the battery. Pain in the arse. But it is better than new now. Thanks for your help.
