ZDriver.com
-   300ZX (Z32) Performance / Technical (https://www.zdriver.com/forums/300zx-z32-performance-technical-47/)
-   -   Bad Gas Mileage (https://www.zdriver.com/forums/300zx-z32-performance-technical-47/bad-gas-mileage-31699/)
andrew404 Dec 16, 2010 12:32 PM
Bad Gas Mileage
I bought a 1990 300zx NA 5 speed with 104k miles a few weeks ago. I only average 12-13 mpg. What could be causing this? I don't drive the car very hard.
domsgarage Dec 16, 2010 01:44 PM
Its a 20 year old sports car. Dont expect good gas mileage.
andrew404 Dec 16, 2010 03:46 PM
I'm not expecting great gas mileage, but from what i've seen online, most people that have my year get at least 16 mpg.
domsgarage Dec 16, 2010 03:51 PM
maybe on the highway.
on the highway/parkway i get great mileage. stop and go / normal driving i get about 12.
andrew404 Dec 16, 2010 03:57 PM
Ok. I thought maybe it could be bad fuel injectors or bad spark plugs because sometimes when accelerating it seems like it loses power throughout the powerband.
domsgarage Dec 16, 2010 04:00 PM
there probably is something wrong then.
first thing to do, check the injectors. they should all ohm out between 11 and 14.
if theyre original, chances are theyre starting to fail.
andrew404 Dec 16, 2010 04:05 PM
how do I check them? and how much do you think it would cost to have them replaced?
domsgarage Dec 16, 2010 04:06 PM
Volt meter.
Same way you would check anything with it.
Pull of the connector. Set the meter to ohms, hold negative / positives on the tabs.
Probably looking at about a grand + between parts and labor. Probably pretty close to 1500.
Where are you from?
andrew404 Dec 16, 2010 04:09 PM
Shoot. Wasn't expecting it to be that much. I'm from Atlanta.
