Auto Box
My autobox won't go into reverse unless I use the lever behind the gear selector. Believe I read somewhere on here about a switch somewhere under the dash or behind the brake that may need adjusting so I can use the button on gear lever to select reverse. Any ideas?
Appreciate any inputs Dukester |
Check your fuses. Also it's called an automatic transmissions, or auto trans for short
