5 things ?!?!?
Old Jun 14, 2003 | 04:42 AM
Riz Z Speed's Avatar
Administrative Brown Guy
The most obvious is always the easiest. The replacement of the air filter to a freer flowing element is usually number one. Exhaust usually follows that. Undercrank pulley would be a good follow up if you follow the hp/$ ratio. Besides regular maintenance, above these steps usually start to get rather expensive not that the exhaust isn't. I recommend the HKS twin power ignition, if you have a turbo model having the ECU done is a great way to get a lot of hp quickly. Otherwise I would suggest bigger turbos or even a turbo timer. If you got an N/A you should maybe try Stillen's headers with some moderate nitrous. If I forgot anything besides suspension stuff, someone'll let me know I'm sure. lol Hope I helped.
Old Jun 14, 2003 | 12:19 PM
If you don't wanna mess with the ECU I don't blame you, besides the ECU upgrades are expensive. Here's an alternative for ya then, try this module from jetchip performance. Lotsa luck and fun
http://www.jcwhitney.com/product.jht...FID=4149&BQ=sc
Old Jun 14, 2003 | 10:21 PM
Actually, I'm not quite sure about the hp gain. But, and its description of features sure sounds just like an ECU upgrade though doesn't it!?! Since we're dealing with N/A's here, I'm going to guess that the gains should be in the neighborhood of an ECU upgrade. Although I don't think the two should be combined. So depending on the state of tune of your car, I'm guessing anywhere from 8-25. Although the 25 is extreme, I figure if you start low you gotta end high, right? Oh and also, I just remembered that to get some more hidden hp don't forget to advance your timing, twinturbo.net has an article about it. Like as if they don't have one on everything!!!! later
http://www.ttzd.com/tech/timingtech.html
Old Jun 16, 2003 | 05:19 AM
Yeah...the only thing that little thing won't do though, is remove the top speed limiter and raise the rev limiter like an ECU upgrade would. But are those things really that important? I've had my 2+2 up to 145 and could have still gone more but I started running out of room and the front end started getting a little squirrley on me so I backed off. But hey, 145 is still really damn fast! I'm not complainin'!!!! I did that when I first got it and that also was after a night of racing all through Chinatown before I even did ANY modifications to the car. Hmmm......I wonder how fast it'll go now...???
Xodus989
May 2, 2014 12:06 AM
KasbeKZ
Mar 29, 2010 01:03 PM
skittle
Mar 1, 2007 02:33 PM
WildmaN
Mar 7, 2006 02:36 PM
BigTDogg
May 7, 2002 09:10 AM
