White smoke from exhaust because of brake fluid?
Old May 23, 2019 | 02:26 PM
Rimacperu's Avatar
Has anyone ever had a brake booster fail and had brake fluid from the master cylinder go inside the booster and then brake fluid got sucked by the vacuum hose connected to the booster and created white smoke to come out the exhaust.reason i found out it was brake fluid was because there was a small puddle of fluid on the ground and when i wiped it, it stripped my garage floor paint. i took the BMC and booster out already(had a whole lot of brake fluid inside the booster) just looking for parts to replace. Once i replace does anyone know if its okay if i run it and have it burn off the brake fluid thats in there? or is there a method to somehow get it cleaned. thank you!
attacksoma
Mar 1, 2011 12:34 PM
jk11blueboi
Oct 10, 2009 11:00 AM
wake2wake21
Aug 3, 2008 04:35 PM
thxone
Nov 19, 2006 09:33 AM
blakeZX
May 5, 2005 10:36 PM
