Whats a fare price for an engine swap?
I have a 93 300zx non-turbo with 156,xxx miles on it.
I called one place and they said 4500 new engine swap. Is that fare for the labor and all? |
I once did the NA swap myself, really easy to pull the engine. Cost me 2k for JDM Motor and parts. They are asking a bit much. If you need more help let me know.
a fare is what you pay to ride on a bus. Fair is a price that is acceptable to buyer and seller.
Originally Posted by rogerz
(Post 320511)
Originally Posted by vuez32
(Post 320500)
I'm planning on doing it myself with help from a friend but is there anything I need to buy on the side, motor mounts, hoses? Also did you sawp the tranny as well or just the engine, cause I found both with about 45k on them for about 1600. THanks. |
motor & trans $1600 (45k miles)
Originally Posted by sidv89
(Post 320522)
(Post 320522)
Also did you sawp the tranny as well or just the engine, cause I found both with about 45k on them for about 1600. THanks. Timming Belt Kit (water pump, belts, bearings) Rear Main seal Oil Pan Gasket Resurface Flywheel(if installing new clutch) New EFI Harness All performance items such as Header, ERG delete, UD pulley and etc should be install while the motor is out. I would run regular oil for the first 1-300 miles. There are alot of stuff that needes to get filter out first. |
I had found a genius mechanic who would look at my Z31 and see a personal challenge, no matter how small or large the problem. He really understood cars - all of them. So I found a good Z31 motor at a recycler, bought it and had it delivered to his house. I dropped off my Z and in 2 days he called me to tell me that my Z had a "new" motor and was running! Happy day. We did the final tuning that night and I drove it home. Total cost for mechanic: $800. All possible because he was a great mechanic - not just into cars and motors for the money. Guys like that are hard to find but worth the search :006:
