Vg30dett Swap HAVE A QUESTION
I have a 1990 300ZX
I want to swap out the non turbo engine with a TT I've noticed that the vg30dett's wired for automatic are muchhh cheaper than the ones wired for 5speed trans. Which leads to my question. Can I just buy the cheaper engine wired for A/T and swap out the ecu and wiring with a 5spd ecu and wiring?? I've calculated this up and it would be muchhh cheaper to do this if its possible. I would also use some parts from the old engine (vg30de manual transsmission) that aren't messed up to save even more money. I'm just trying to get the TT power without spending a sh*t-ton of money. |
Yes you can. That's how I did mine. Just be warned that the automatic engines had slightly smaller A/R ratios on the turbo.Also the cams are smaller lift on the automatic. I swapped my n/a cams in because they are the same as tturbo manual cams. I Mic'd them back to back and the difference in lift was significant.
If you upgrade to a tturbo flywheel you will need to clearance the transmission bellhousing. If you keep the n/a flywheel then you are fine. |
Originally Posted by ConnecticutZX90
(Post 321993)
I have a 1990 300ZX
| All times are GMT -7. The time now is 11:00 PM. |
