Tach and speedo wires for turbo timer
Any one know which wire I tap my wires into for the speedo and tach? According to the service manual the tach is wire 22? For the speedo it has 5 different wires, which one?
WTF do you need to know the speedo and tach wiring for when installing a turbo timer? the turbo timer just needs to keep the ignition on after the key is out.
... and a good turbo timer self-calculates the time the turbos need to cool down based on how hard you were driving it for the several minutes prior to turning the engine off, and also kills the engine if the car registers any speed after the key is removed (this prevents THEFT!)...
Familiarize yourself with TwinTurbo.NET. And when I say "familiarize," I mean "do what I did... read everything... even tech articles for products you don't own. You'll find everything you ever need to know somewhere on that site." http://www.twinturbo.net/nissan/300z...avcr/avcr.html Step 6 has your answer. |
This turbo timer calculates 0-60 times, 1/4 times and data loggs the rpms... But yes if I wanted a simple turbo timer I could have spent 30 bucks and plugged it rigth in. I guess I'll figure it out on my own with the multi meter....
Originally Posted by Mrmoose
(Post 290142)
[Adam Sandler voice] Once again, things that could have been brought to my attention YESTERDAY! |
That is true... Can't wait to see my 0-60 times and stuff, new toys are great.
(Post 290150)
Useful info that you SHOULD have included in your first post. :D
(Post 290124)
... and a good turbo timer self-calculates the time the turbos need to cool down based on how hard you were driving it for the several minutes prior to turning the engine off, and also kills the engine if the car registers any speed after the key is removed (this prevents THEFT!)....
Guess I'm just splitting pointless pubes here though.... |
it does not need it to keep it running.... it needs it to calculate 0-60 times, 1/4 times and lots of other data.
anyways i found the wire, thanks for the help. |
Originally Posted by hoov100
(Post 290167)
So will wiring it to the switch for the brake pedal/clutch. I have yet to use/install a turbo timer that needs to be wired into the speedo/tach to calculate how long to keep the motor running.
(Post 290142)
Ha ha ha so you did! I did not even realize there was a link as I was just skimming over looking for the color of the wire. White it is, my mistake. Thank you sir!
