Spark plug input (Is more spark is better???)
I found 3 spark plugs I was thinking of buying. 1st is called PowerSTAR Performance Spark Plug:fplasma: where it shoots out 8 parks at the same time you can see the video links below. The 2nd one is Pulstar Pulse Plugs (Iridium):fenforcer: were it shoots out one strong spark. Last but not least the VTA 3D Spark Plug::s-shock: were it shoots out a 360 spark. :s-bluecap:So what do you guys think and your input?:s-ctf:
Powerstar Pulstar VTA 3D |
Been proven a million times they are a gimmick and waste of money.
Use the factory spec NGK's: •NA: PFR6G-11 •TT: PFR6B-11B |
Yup NGK. I have had bad luck using anything but in both the VG and the L28.
Ok thanks you guys for your help (NismoPick,Skully) I will be going to the NGK Spark Plugs
