Questions
k i dont know alot about cars i'm really starting to learn and i've always wanted a 300zx not the car to start with so i've heard but never the less its what i got so if you guys could answer a few of these questions for me i would greatly appreciate it
I have a 1990 300ZX twin turbo t-tops already have a cool air intake dual exhaust all the way to the manifold short shifter boost gauges water temp gauge intercooler piping and thats about it However my turbos are going out the seals are cracked and the burning a small amount of oil i know this is a serious problem but just how serious? i have to drive it about 600 miles to get my other car what would happen if my turbos did blow out? destroy the engine completely? slight damage? Next ? would be how much would it cost to rebuild the motor i already have it has 123k miles on it seems like everythings ok had it looked at compression test done or how much would it cost to replace it outright? also anything i should check out on the car that people like myself wouldnt know to check on a import car like this? Edit: Also how much would it cost to rebuild the turbos? |
turbos blow car runs like shit pay money to fix, lots.... shouldnt be engine damage
engine rebuilds are all relative to what is done no one can answer that question. but if you do all the work except the machining it might be 400 dollars, but if you have them do it all get upgrades blah blah blah it can be 6k if theres nothing wrong with the car i doubt theres anything that needs to be checked other than watch for rust and you can try running the ECU codes see if theres any hidden faults bu the check engine light shold come on if im not mistaken also getting 2 turbos rebuilt isnt bad probably 3-400 dollars collectively. the problem is getting the turbo's out |
NOOB: seems like everythings ok had it looked at compression test done or how much would it cost to replace it outright?
this doesn't make sense. did you check the compression or not? how was it? if the compession and oil pressure are both fine, you don't need to worry about a rebuild unless you plan on major upgrades. that block should be good for AT LEAST 200,000 if it's taken care of at all. as for the turbos going out, snw disagrees, but is it not heard of that shards coming from the damaged turbos will go into the engine? i thought i'd heard of it before, but i'm no turbo expert. |
if you shatter the turbo maybe but thats why most companies doent use ceramics lol. when the oil seals go it starts to smoke and eventually leads to failure usually the bearings wear and it starts to walk and wear on the walls and it just doesnt spool anymore. i suppose its POSSIBLE but i've never seen it happen
seen it happen on ebay turbos :) but the turbos will seize up
yeah so the moral of the story is don't go on a 600 mile drive.
im sure he will be fine driving it for a short time. its just bad seals.
rebuilt turbos are not the greatest idea. but if youre on a tight budget.... |
lol never said i thought it was recommended either, just answering the question. if i was going through the hassle to replace the turbos on a Z32 im doing it once and for all so im doing it right... upgrade
That is Man Law Section 1, Paragraph 3.
In brief, Man Law Section 1 Paragraph 3 states: "Thus, anytime a part breaks on said car, truck, motorcycle, aircraft, boat, or any other form of transportation thereof involving an engine or other combustible means of power production. A Man must upgrade said part with another of greater value, stronger material, or anything that improves the power of previously mentioned means of propulsion." I am just stating the book. Do not forget the Man laws. If we start forgetting the well known man laws we are no better than the French. No offense to any hairy women lovers. You guys are cool in your own way. Wine has alcohol. That counts for something. |
lol, theres only one word i know in french, and thats surrender :D
Appreciate all the answers guys
I know its not a good idea but i just got back from Iraq and this is the only car i have at the moment my other one is in kansas which is 600 miles from here i was told if i dont accelerate fast it'll save the turbos so i plan on doing that As far as upgrading yeah i'm just gonna let it sit at my place in kansas until i have the cash which should be in a few months and just have them replaced with the best thing i can find....any suggestions? man law! |
Just back from Iraq?
Thanks for the service! THe VG30DETT is kinda a pricey engine to play around with. This kit looks to be pretty solid. I am sure some searches could bring up more answers. Either here or on hybridz.org. http://www.thezstore.com/page/TZS/PROD/PTC06/10-1942 |
ugh... this aint a classic Z ratfink. Z1 and JWT are good places to hit up and TT.net for info and classifieds i wouldnt go to any other forum for info on a Z32
for suggestions search around for stuff Zlover has posted |
Whatever. That's why I said to do some searching.
Hybridz is a site I know with more info on the VG30DETT. |
they are smart over there and some are good with that motor but usually not in the Z32 itself in a swap. but a select few, they tend to stick straight motors in or V8's not many V6 swaps
Yeah, that kit is a damn joke (GT2530's were only $3650 and will do 600rwhp... Sport 500's will make that power at only $2000). They don't even say what they are.
But I'd also never really trust any repairs that Z1 does, like putting 'new' cartridges in stock turbos... there was a big fiasco a while back about them selling someone what they said was their Sport 500 equivalent when really they just sent him a pair of stock turbos (both use stock housings and both are made in-house, I believe). I avoid Z1. |
zlover if you avoid z1 then where do you do must of your z car shopping i would really like your store preference list. pm it to me if your want
I said look. Not is. I also said to ask around in places like Hybridz that seems to have a better wealth of knowledge with Z32's.
I would probably never buy a kit for any vehicle. I would rather go through the boost maps and find something that I know will fit what I need. |
conceptzperformance.com specialtyz.com splparts.com for suspension theyre all in rizz'z link page |
Originally Posted by b300z
importpartspro.com
conceptzperformance.com specialtyz.com splparts.com for suspension theyre all in rizz'z link page You can get anything you need from just those four vendors. And HybridZ isn't the place to go for a wealth of Z32 knowledge... TwinTurbo.NET is. It is the capital of the Z32 world. |
| All times are GMT -7. The time now is 07:38 AM. |
