power transistor unit harnesses
Old Nov 29, 2005 | 05:46 PM
somguy2u's Avatar
i think this is the right term for it.
its in the front of the engine bay (for me at least)
anyway its a decent size plug - i see two connections, not really sure waht either of them are - aftera serach i couldn't find much. i will post the pics later
but if its not this
http://www.courtesyparts.com/Merchan...de=22020-00Z32
its something that looks darn close to it.
anyway - so i spent about 2 hours trouble shooting injector wiring and harnesses and ignitors wiring, themselves yada yada.. well when its all said and done if i stick this little harness and wire bundle in the right place it all works like a dream, if its not in the right place it goes to absolute hell. so there are loose connections all over this thing. Is this something worth replacing , how indepth is it? i don't want to replace it and then still not have it work. 200$ is a lot to not fix the problem. that and i just need the wires i think.
any one else ever have this problem?
(sorry if i missed it in the search i tried)
Old Nov 29, 2005 | 07:13 PM
emo236's Avatar
confuzed member
good luck for you, it's a recall. Go to Nissan (dealership) and have them check if the recall's been done on your car
Old Nov 29, 2005 | 07:21 PM
Riz Z Speed's Avatar
Administrative Brown Guy
so the PTU works just the wiring is bad?
So is there a question there somewhere that i missed?
Old Nov 29, 2005 | 09:16 PM
91zxtt's Avatar
I thought the recall was only on the 90's.
Old Nov 29, 2005 | 10:38 PM
emo236's Avatar
confuzed member
I had the recall done on my last 91.
Old Nov 29, 2005 | 11:53 PM
napoleonzheking's Avatar
F5 Hero
Recall was done on my 91.. it doesn't matter if it was done or not, they won't do it now for free. PTU WIRING going bad is a common problem, unfortunatly, you can't buy just the harness. YES it's worth replacing. PTU is like one of the most important eletrical components on the car... can't run without it.....
Old Nov 30, 2005 | 02:12 AM
https://www.zdriver.com/forum/showth...5639#post25639
pic of recalled ptu vs replacement ptu in this thread.
Old Nov 30, 2005 | 06:57 AM
somguy2u's Avatar
ah ha - thanks guys
i've noticed the car doesn't run without it haha
unaware this was a recall - i will look into wether it was replaced or if i can get a free one, doubt i can get a free one after 14 years haha
Old Nov 30, 2005 | 08:52 AM
emo236's Avatar
confuzed member
Mossy Nissan here in El cajon, said they'd replace them if it's never been done on your car. they can look up the VIN. oh and this is for free.
Old Nov 30, 2005 | 10:10 AM
F5 Hero
Nissan needs to just start selling the harness sepratly...
Old Nov 30, 2005 | 02:00 PM
emo236's Avatar
confuzed member
sorry, I said replace, I meant relocate, you're right, they won't replace them.
Old Dec 7, 2005 | 05:54 PM
Milo (SZM mag)'s Avatar
Wide Body Magazine Guy
answers....
It's called the sub-harness. Nissan still sells the newer style PTU and it comes with the subharness as well. Concept Z Performance has it listed on their site.
But- a simple fix is to simple cut the connectors and hard splice them in. I have done it on about 12 or so cars here locally and it usually always help eliminate rough idle due to the PTU connections and wires to the connectors being overrun with that green residue that interfere with current over time. Mainly due to moisture, time and massive amount of heat being located where it is in stock form. A new trend is to re-run the unit next to the air filter to keep it much cooler, combine that with the wire splicing and any issues with it should clear up if in fact that is the issue.
Good luck.
Old Dec 7, 2005 | 06:01 PM
green stuff is corrosion and is a result of all that stuff you mentioned.
good idea with the relocation Milo.
Old Dec 7, 2005 | 06:15 PM
Anything for you.
BTW- Napster owns Metallica. Double
Old Dec 7, 2005 | 06:26 PM
Hey now, no need to get personal.
Old Dec 7, 2005 | 06:48 PM
emo236's Avatar
confuzed member
good insight, Rizz! You have this talent of repeating the previous post and making sound like you added something new...haha. the relocation is what the dealer will do as part of the recall.
Old Dec 7, 2005 | 07:35 PM
Wow, great observation Emo.
You have this talent of pointing out the obvious and making it sound like you're the first to do it.
I think you are no longer confuzed. Captain Obvious might just suit you as a better title.
Old Dec 7, 2005 | 10:56 PM
emo236's Avatar
confuzed member
haha, we'll have to see....watch my habits for a bit and see where they take me. As long as we have bardabeze on this forum, I'll be confuzed.
Old Dec 9, 2005 | 11:18 AM
F5 Hero
One word of caution to relocating it, It can get hit with some moisture when driving in a heavy rain. Not much though, I put mine inside the air filter tube since I have a pop charger and hole punched a hole and zip tied it secure, but it still gets hit with some moisture in a heavy rain, especially since my car is lowered. One thing to think about.
Also, when you relocate, make sure you leave plenty of slack on the ECU coolant temp senesor lines and the other one right there, other wise, it puts pressure on them and causes them to break easier and if your ecu coolant temp sensor plug is broke, causes it to come off easier.
I'm a big fan of the relocation, makes the engine bay look alot cleaner less wires running around and stuff.
19872plus2
Sep 28, 2013 05:05 PM
NC280Z
Dec 15, 2012 06:53 PM
mwest300zx
Jan 8, 2012 11:38 AM
dkrzan
Sep 13, 2010 06:16 PM
kmasterx75
Dec 21, 2008 05:18 PM
