By-pass Hoses / Heater Hoses???
Old May 1, 2005 | 09:28 AM
CanyonCarver's Avatar
Jack Of All Trades
I'm getting ready to do my timing belt replacement. One of the things I'm going to do at the same time is to replace ALL of the rubber water and vaccum lines. My question is, Are the by-pass hoses and the heater hoses generally the same thing? CourtesyNissan has a by-pass hose kit consisting of 12 hoses. Kragen parts on-line has 15 different hoses called out under heater hoses. I'm leaning towards buying the Courtesy kit, but alot of the hoses look like straight pieces that can be cut from a length.
If any of you have done this yet/recently (91?), do you specifically know what diameter the heater hoses are? ....... the PCV hoses? ....... Vaccum lines?...... IACV/AAV hoses? I'm planning on the red silicone vaccum hose.
Thanks.......
Old May 1, 2005 | 10:00 PM
91zxtt's Avatar
The hoses that run to and from the heater core should just be bought from Courtesy. They're a very unique shape. The vacuum hoses are all 3-4mm and 6 mm. I used all 3mm and 6 mm. I believe all of the coolant hoses are also 6mm. A couple of the PCV hoses are different sizes at each end, so just buy the hoses from Courtesy.
skygunner58203
Aug 28, 2012 04:17 AM
vrocious
Feb 15, 2008 08:43 AM
raythenegr0
Dec 7, 2007 08:23 PM
q8orange
Oct 29, 2005 01:22 AM
phattie
Sep 7, 2003 10:19 PM
