Not firing on No.6!!
Hi there guys. well where do i start. me z has been running fine since i rebuilt it about 7months ago, but come to it today after it has been standing for about 5 days and its started missing on No.6.
After replacing the old MAS/MAF (hence being off the road for a few days) it was ok for about 3-4 mins of driving and then out of the blue, a constant miss. now i have gon as far as to check the coil pack and to see if there is a spark and that is fine, if checked the injector and that was ticking, ive even replaced the injector incase of a blockage, but still it is missing on that darn cylinder. i did an ECU check and atfirst it came up with code 21* i gave a few things a "wiggle" and it went. but it has not solved my missfire. Could it be the PTU even though its sparking, or what i was thinking was there was a problem with the Crank Angle Sensor and causing it to not fire right on that particular cylinder. Any thoughts would be much apriciated. Adam |
Did you try removing the Spark Plug and checking it?
Fire to the coil pack doesn't mean the plug is going to fire... You still need a good plug. Rod. |
did you check the wiring that connects to the coil pack to make sure it was on secure?
hi there. yes i pulled the coil pack out with the spark plug and there was a spark.
| All times are GMT -7. The time now is 03:12 AM. |
