No throttle responce
Hey guys im new to z world just purchased my first 32 2+2 about a month ago. I have 2 issues or it could b one in the same first my front calipers seem to b sticking randomlly i can put it in neutral nd it wont roll for long or when i try to move i gotta tap the acc allil for it to budge nd i hear the creekin noise as iff i had my foot on the brakes so should i just put new orings in em or is it a diff issue like lines, nd my pedal sinks but i have no leak i have pedal if im goin in the cittty where i got no real speed goin but coming to a long stop i loose em it goes str8 to the floor i pump it nd it starts slowin down but idk if thats the same concern with the calipers..///second it happend 2 times so far:022: I tried steppin on the gas nd i haddd no response it was moving but slowwwwww until it got to like 50 it started pickin up i was in 3rd i went down to 2nd but nuthing so if anyone has any ideas i would gladly appreciate
Complete 120k mile service kit there is no receipt for it being done in the pat 4 years, bleed the brake system, adjust/replace the ebrake shoes. As for doing it all there are more then enough sites with write ups, jut google it. if your brakes continue to suck, replace the M/C and rebuild the calipers.
I replaced the rear pads shoes i kno i need to change the fronts are good i bleed em when i changed the rears i drove it home no issue until acouple days i drove it again nd it happend what should i include in the service besides air fuel plugs i put some bg maintenace stuf in the fuel nd the oil.
The 120k timing belt kit. timing belt, plugs, water pump, cam and crank seals, idler and tensioner, idler studs, crank sprocket, accessory belts..etc courtesyparts.com
As for brakes, make sure a bleeder didn't come loose. Also before anyone complains, please use complete words and grammar. I'm having one helluva time trying to figure out what you are saying. |
| All times are GMT -7. The time now is 07:04 AM. |
