Newbie with a problem...Whats new? Lol
Old Feb 2, 2012 | 03:43 PM
dave1208's Avatar
Whats up guys? I just bought a 91 Z32 TT about a month ago for about $1000. Only problem of course, is that it doesn't run. The guy I bought it from was pretty old and just wanted to get rid of it, so I gladly took it off his hands. What he told me was that none of the pistons had compression. I found that really odd because the car only has about 70,000 miles or so. He also told me he knew very little about cars so its kinda hard to trust his opinion. when I start the car it makes a weird whirring type of sound like if the starter is not fully engaged or something. It sounds exactly like this youtube clip of a Z with the same problem.
http://www.youtube.com/watch?v=96gAkKLjPZE
A couple of days ago I took the starter to the auto parts store and had them test it, but the guy said it was good. So, would a good starter still not function properly when in place?
Any help would be appreciated.
BTW, whats wrong with the search tool on the site? Its not searching at all.
Old Feb 2, 2012 | 05:17 PM
Is the motor turning over when you hit the starter? is it the correct starter? have you verified the starter solenoid is pushing the gear out?
Old Feb 2, 2012 | 05:32 PM
dave1208's Avatar
The motor is not turning over. It is the correct starter because its the stock one, and no I haven't verified. How would I check the soleniod?
Old Feb 4, 2012 | 03:52 PM
dave1208's Avatar
Quick update,
I changed the starter and still the same problem. Fuel pump is ok, and the ECU is reading no codes. Also the motor is in time. I'm stumped!
Old Feb 4, 2012 | 05:20 PM
Rupe's Avatar
Horsepower Mathematician
@dave1208
Originally Posted by hoov100
[...] have you verified the starter solenoid is pushing the gear out?
Wish I could answer your question about how to do this though. Must be somewhere out there though.
Old Feb 4, 2012 | 06:00 PM
dave1208's Avatar
Its ok I got a new one, but still no difference.
Old Feb 4, 2012 | 06:14 PM
ThaPimpShrimp's Avatar
So it is as if the starter isn't hitting the ring gear on the flywheel?
Old Feb 4, 2012 | 07:48 PM
dave1208's Avatar
Yea it seems like that.
Old Feb 4, 2012 | 10:28 PM
Rupe's Avatar
So is the solenoid part of the starter assembly?
Old Feb 5, 2012 | 01:04 AM
zordietrying's Avatar
I had this happen to one of my Zs and there was a few teeth missing on the fly wheel. (from hitting the starter when the car was running) Put the car in gear and push it just enough to get the fly wheel to move a few inches. Then try to start the car.
Old Feb 5, 2012 | 01:37 AM
Try this, or since you're already switching starters out (No idea how easy it is on this car, not really familiar with it) Look inside and see what the flywheel looks like. (Again if that's possible with this car haha. )
Old Feb 5, 2012 | 06:32 AM
dave1208's Avatar
I took a look at the flywheel from under the car when i changed it. It looked fine. its working fine, but the car just doesn't want to crank all I get is a whirring sound. I see the cam gear spin inside so it can't be the starter. Its got to be something else. I'll try to post a vid soon so y'all can see. Easier than trying to explain lol.
Old Feb 7, 2012 | 01:04 PM
dave1208's Avatar
Here's the video as I promised. I shot this yesterday afternoon, so let me know what you think.
http://www.youtube.com/watch?v=f8VU-...ature=youtu.be
Old Feb 7, 2012 | 04:23 PM
I think the bigger mystery is what happened to your timing covers and what that mystery sound is when you are cranking it over.
No starts are easy, you need fuel, air, spark and compression. Check back when you have checked them, if you need help with it, the FSM can help you.
Old Feb 8, 2012 | 12:31 AM
Rupe's Avatar
That sound is CREEPY
Old Feb 8, 2012 | 12:18 PM
dave1208's Avatar
Just checked and no spark. Also, gas is brown/orange with a weird smell. Checked with Nissan and they never did the PTU recall on this car. I couldn't check compression since the car doesn't crank. Just has that weird turning sound.
Old Feb 9, 2012 | 12:19 AM
Rupe's Avatar
In the video all your belts are moving. Doesn't that mean your engine is in fact turning over? And you just said that there's no spark, so I think there's something to look into...
Also, if you've been cranking it all this time and the fuel's been injecting into the cylinders, they could be flooded with fuel which would also be adding to you problem. If your fuel isn't moving, then you're in luck on that but then you have another separate issue to deal with.
Old Feb 23, 2012 | 05:46 PM
dave1208's Avatar
I've searched for the answer to this, but no luck.
How do I know if my engine is flooded with gas?
I know I can pull the fuel pump fuse and crank it to unflood.
Old Feb 23, 2012 | 11:51 PM
Rupe's Avatar
Well if you pull a spark plug and see gas pooled up in the cylinder, I would consider that to be pretty well flooded. Did you get it to spark yet?
Old Feb 26, 2012 | 08:10 AM
dave1208's Avatar
Yea! I got a new ptu and now they spark. Now I need a new set of injectors since they all have a reading of 00.01. I think this problem is solved.
Old Feb 26, 2012 | 02:32 PM
Rupe's Avatar
Good luck, hope to hear everything goes well.
Old Mar 4, 2012 | 03:06 PM
Dkdragon22's Avatar
Ever figure out what it was?
Old Mar 4, 2012 | 04:54 PM
dave1208's Avatar
Yea, it was the PTU and fuel injectors.
reefer24131
Sep 11, 2013 09:58 PM
feathersem
May 11, 2010 09:40 AM
BackHouseZ
Jun 7, 2008 09:10 AM
kookymonkey69
Aug 3, 2005 04:38 PM
