need some help
hey guys i was wondering if any of you have extra or know where to get the two plugs on a 91 300zx n/a tps the ones attaced to the harness.
here why the plug on the front i found out has been messed with and is now broken and the one in the back the middle wire is so coroded it broke off now my z is running funny so any help would be greatly appreciated |
1.5 sentences... and as a result, I can't really tell what you're asking. "two plugs on a 91 300zx n/a tps the ones attaced to the harness" does not compute. Sounds to me like you're saying there are two TPS's... of which there are not.
yeah sorry bout that zlover
here are some pics i just took to help me explain the first one here is a picture of the plug on the wiring harness that attaches to the tps on the front most part of it. you can see where someone decided to tie two of the wires together and that the plug is coming apart. http://<a href="http://s432.photobuc...tobucket"></a> this next one is of the other plug that attaches to the wire that comes out of the tps as you can see it has a broken wire in the middle http://<a href="http://s432.photobuc...tobucket"></a> these are the plugs i need. btw i had unplugged both of them and my car runs ok without them plugged in and its not tripping my check engine light |
any other ideas on how to fix this problem?
courtesy nissan i expect will have those connectors.
i searched them a little bit, and didn't find any there, but i found this through a google search. this person may not be selling any more. i didn't check the date. at any rate, it's easy to do a search for them http://www.aus300zx.com/forum/archiv.../t-259299.html |
People replace harnesses.
Here's an idea, put up a want ad for someone who just did a JDM engine swap or just replaced thier wiring harness to clip those connectors for you so you can pig tail them in.
try to email this guy http://www.yugobernie.com/. he's the member on tt.net and he might has the parts you're looking for.
also check here, new TPS. http://www.courtesyparts.com/betasit....php?keywords=[22620]+\(z32&cPath=882_883_900_901 |
