ZDriver.com
-   300ZX (Z32) Forums (https://www.zdriver.com/forums/300zx-z32-forums-7/)
-   -   My Z-ZEN build (https://www.zdriver.com/forums/300zx-z32-forums-7/my-z-zen-build-39292/)
madigity Mar 6, 2014 10:16 AM
My Z-ZEN build
Hello everyone I have a 1992 300zx that I decided either restore or build. I decided that restoring it would be cool, but after research I decided that the amount of money it would take to get to the power level I wanted would be a lot. And even then the motor may not hold 800-900hp. So I decided to research what foreign motor could take the most abuse and benefit the most from bolt on’s. also i did not have to go deep into the motor. My choice would be the 2jzgte engine. I figured I would have one of the best looking cars and one of the best engines of the era. My plans are loose at this point but what I know I want is complete the drive train first and get the car running. below is a list of parts. Most I have already got. I have been sourcing parts for the last 2 months
• Engine & Trans-
Wire Harness Extention - *Fabrication Labor -
*Cross Member /Oil Pan fabrication - Engine & Trans Mount
- Water Pump & Seals
- Tial Wastegate 44mm
- Tial 50mm bov
- Turbo
- Exaust manifold
• Drive Shaft
• Electronics
- AEM V2 Stand Alone
- AEM Y Band Fail Safe & Guage
- Boost Guage
- Temp guages
• Fuel
- An-10 bung welded to fuel tank
- Bosch 044 inline pumps
- Ross fuel rail
- Injectors 1000cc
- Fuel pressure regulator
• Cooling
- Intercooler & piping
- Oil cooler
- Race radiator
- Trans cooler
• Brake upgrade
- Rotors
- Pads
• Paint
madigity Mar 6, 2014 11:11 AM
1 Attachment(s)
Here is a pix of the car. I love this body style
madigity Mar 6, 2014 12:24 PM
so i as stated i decided to buy majority of the parts first at least the big parts. and as for any fabricated parts, i decided to buy spare parts and have them fabricated, without using my parts of my car. this allowed me to continue to drive the car longer while i source the parts and when time to statr the build, down time for fabrication will be minimal.
madigity Mar 6, 2014 12:34 PM
3 Attachment(s)
now that i have the engine i need to obtain parts to make it fit. after some research i found a company in Millersville Freed Engineering. a company that has done a few of this particular build. and met with Ben Freed. a very knowlegable man when it comes to swaps. so he goes over a few pitfalls of this build that he had overcome and at the end of the meeting i had brought a k-member, custom mounts, cross member, and oilpan. including fabrication they came to almost $1300
oil pan had to be knotched
madigity Mar 6, 2014 12:48 PM
6 Attachment(s)
cross member, engine mount bracket, and modified k-member, and solid mounts. i read on one form where a guy brought a set of engine mounts from Freed and stated they did not fit. but the fact was that he had them on the wrong side. so i thought it was cool that the mount brackets were marked L&R
madigity Mar 6, 2014 12:53 PM
3 Attachment(s)
k-member modded
madigity Mar 6, 2014 01:01 PM
And i cant forget the Co-Star!! the Engine & Trans. but i have thoes pix attached to another thread 300zxtt vs 280zxt build. so i cant upload again but you can see the pix there
madigity Mar 6, 2014 01:11 PM
4 Attachment(s)
now i got to have the driveshaft modified so Freed modified them also.
madigity Mar 6, 2014 05:49 PM
4 Attachment(s)
just got word that my turbo just came in!!!!! i will post pix tomorrow but for now here are a few more pix of the car as i got it
kingkong_876 Oct 9, 2022 02:22 PM
What engine mount you used to install the 1uz in your z32?
