Muffler temp and other random question
Old Jul 6, 2010 | 08:37 AM
bnhunt's Avatar
First of all, want to say thinks for everyones help in the past...
Picked up a used Borla exhaust with some slight rust on the hangers. Was gonna wire-brush off the rust and then paint it to ward off any future rust. Just around that area and maybe on the rest of the mufflers. I already have some Duplicolor Engine Enamel that says it will withstand intermittent temps up to 500 degrees. Will this be ok or do the mufflers get even hotter than that? I wouldn't think they do, but mufflers is not one of the things it lists as the paint being good for.
Other question, anyone else have a problem with the inside of their rear window getting really dirty? I'll clean it and a week later there will be a layer of something on it.
Old Jul 6, 2010 | 12:49 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
500 degree paint is sufficient for mufflers. Make sure to sand and prime or it'll flake off easily (yes, I have experience with that).
As for the dirt on the rear window, you may have a bad seal around the hatch or tail lights that is allowing carbon from your exhaust to get in. No easy way to diagnose this... if you have a friend with a fog machine, fill the car with fog while it's in a garage and look to see where it leaks out from. I'd say you could also try a smoke bomb, but those smell far worse than fog.
Old Jul 6, 2010 | 11:04 PM
hardenstine's Avatar
also the wind shield whipper the rubber piece come undo which allows water to come in when it rains try to seal it up that can allow water to move in your back hack when its open
Old Jul 7, 2010 | 08:59 AM
bnhunt's Avatar
Thanks good to know i can use the paint i already have. Guess i need to go pick up some high heat primer though.
No access to a fog machine. I do have aruba daves windshield wiper delete which i installed a while back with some silicon sealant. But i suppose a leak may have formed there recently. No visible wet spots or anything though.
Old Jul 12, 2010 | 11:10 AM
napoleonzheking's Avatar
F5 Hero
Bucket of dry ice with water poured on it.....
Old Jul 12, 2010 | 03:07 PM
This is a good idea (much better idea than recommending someone relocate a sensor that was designed to be in a specific spot lol).
cpark_12
Dec 29, 2012 04:32 PM
J-cubZ
Nov 29, 2010 09:01 PM
z32driver
Nov 1, 2010 09:56 PM
jtschmitz
Sep 17, 2009 04:55 PM
Myxtreme2
Aug 11, 2002 10:38 AM
