Looking at a '93 TT, need advice
Old Jun 2, 2004 | 07:22 AM
tsefreeflow's Avatar
I'm Chillin
I would always be wary of a TTZ with over 100k miles on it. If you do buy it you need to take into consideration that in near future you may need to replace turbos. $3-6,000. Unless you take them out and just rebuild them yourself. You should check the cause of the shimmy closer. It might be the rotors but it also may be the tension rods (about $200 upgrade). THe bushings will start leaking after some time (usually around 100k). They will need to be replaced if they are leaking. Look for oil leaks. I dont really fall for the early throwout bearing failure. I have changed many many clutches in my time and never had a problem with that one, but it could happen I suppose. The power antenna is an easy fix as with the rust. Well I think a fair price for this car would be around $5000-$8000. $8000 being the extreme high side. I would try to offer like $4-5k and see how he takes it. With all of those problems you mentioned I would never go above $8k and I might not even do that. My .02
Oh also check the shifting. Make sure that the gears shift smoothly and no grinding. If so you will need a rebuild sometime and not to mention the grinding gears is annoying. I think that is it.....We'll see
Old Jun 4, 2004 | 11:17 AM
91zxtt's Avatar
I have over 150k on my '91tt with the original turbos. I've had no problems. 100k on these cars is not a big deal. You said it's been running Mobil 1 for years, so the turbo bearings should be fine as long as he changed it at the proper intervals and did not run low on oil. The Control Arms could be the cause of your shimmy. It's an easy job and stock arms run $150-$175. If it still has the original factory shocks and springs, then you should consider replacing or upgrading. $12k is pretty steep for this car. $4k-$5k is way low. $8k would be a fair offer. The grinding that you hear when you shift are the synchros, not the gears, and it's common. The manual trannies in these cars are bullet proof. I would question the throw-out bearing as well. Unless the clutch was installed wrong at 83k, I've never seen a throw-out go after 20-25k miles. If the '91 has fewer miles and a lower asking price, if it's in similar condition, then I'd take that car, but the '93 sounds fairly solid.
drey
Aug 10, 2011 03:54 AM
n00blar
Jun 19, 2007 07:14 PM
efrain
Sep 17, 2005 07:20 AM
280ZX_AV8R
Aug 27, 2005 06:08 PM
Dave
Apr 14, 2005 04:14 PM
