:( I need help too!!! :(
Old Oct 18, 2004 | 09:02 PM
bardabe's Avatar
Bad Speller
ok so I was on my way to school today right. an dmy belts just won't stop sqeaking. (they are about 3/8" thick) and I notise that after being on stop and go trafic for about 45 minutes My car is burning hot!!! I glanced over @ the temperature gauge it's about 3/16" from the H and I notice that when I start hauling *** again the temperature goes down slowly. then on the way back home it did not get that hot because the trafic was not that bad. I get home and I pop the hood I see there is alittle Antifreze driping from the bottom of the car. i decide to let it sit for like 10 mins then I open the radiator cap and itlooks pretty dry. I decided to putwatertop it up. I took the car for a drive and it did not get hot @ all but I just took it arround the block. so do you guy's have anyclue what might be going on? ? ?
Old Oct 18, 2004 | 10:39 PM
Riz Z Speed's Avatar
Administrative Brown Guy
First, tighten those belts.
Second, look for a possible leak.
Also, check your connections for the temp gauge and coolant gauge located directly in front of the fan on the output pipe of the water pump. Failure of either of those would result in a overheating issure. Happened to me once, bad connection.
Old Oct 19, 2004 | 10:30 AM
91zxtt's Avatar
If the cooling system is dry, then it's difficult for the temp gauge sensor to give you an accurate reading. Running the system dry can damage your radiator and water pump, so don't drive it without coolant. As Rizz said, tighten your belts. If coolant is leaking onto your belts, that will cause them to squeal also. When coolant dries, it is quite sticky. Try cleaning off your belts and applying a belt dressing to them. Good luck.
Old Oct 19, 2004 | 10:36 AM
lightspeed's Avatar
Southern Speedster
Thermostat got stuck half way open?
Old Oct 19, 2004 | 11:58 AM
CanyonCarver's Avatar
Jack Of All Trades
A new radiator cap on mine a month or so ago solved my missing coolant / coolant smell / running warm problem. $6 I think
Old Oct 19, 2004 | 12:15 PM
91zxtt's Avatar
My Z31 did that. Remember the KISS theory....keep it simple stupid.
Old Oct 19, 2004 | 03:28 PM
Z_WRECKER's Avatar
with older cars it's a really good idea to check all of your fluids every other day. Y ou have to make sure everything is there, or it could cost you a whole lot more money to fix... like 91zxtt signature says... "If you don't have time to do it right the first time, how are you gonna have time to do it over" I love that
Old Oct 19, 2004 | 07:44 PM
bardabe's Avatar
Bad Speller
Well I found everithing out. My water pump is Leaking and also the metal pipes that go to it. all the three belts are gone too. so what Im going to do is teh following:
-The 120,000 Mile timing belt cervice from Concept Zperformance.
-02 sensors
- Radiator fluid temperature censor
-OEM MasterKey New one
-flush the radiator
what u guy's think? anithing else I shoudl or shoudl not do?
Old Oct 20, 2004 | 10:23 AM
91zxtt's Avatar
You may want to consider replacing the rubber lower radiator hose with the aluminum lower radiator pipe. I see them on ebay all the time for like $50. Courtesy sells them for $80. Stillen sells them for about $120. A pipe's a pipe. I replaced mine. It's a good upgarde. What all does the concept z kit come with? Have you thought about installing underdrive pullies? If so, now would be a good time to install them.
Old Oct 20, 2004 | 11:38 AM
DanZ32's Avatar
Dan's the Man
I agree with 91, now would be the best time to think about UR pullies. I did my 120 service when I bought the car (at 95K miles...didn't want to take any chances). I also bought the 120 kit from ConceptZ...has everything the 60K service has plus the idler pullies. I put in the full set of UR pullies at that time.
If you do decide to go with the UR pullies be sure to tell ConceptZ when you order 120k kit so they can include the proper size belts that will fit the new pullies.
I wish I thought about the lower rad pipe at the time. After we had everything back together it dawned on me...it's the age I tell you, I forget everything.
Old Oct 20, 2004 | 03:21 PM
91zxtt's Avatar
Either that, or it's the malted hops and bong resin? How old are you? I figure you can't be that old with Stewie and Brian as your avatar.
Old Oct 20, 2004 | 04:54 PM
bardabe's Avatar
Bad Speller
lol yeah. Im going to do that I'll see the radiator pipes. also Stuey and Brian kick *** man. Leave em alone
Old Oct 20, 2004 | 05:37 PM
91zxtt's Avatar
I saw these chrome water inake pipes on ebay today. They'd probably look kinda cool. http://cgi.ebay.com/ebaymotors/ws/eB...929442281&rd=1
Here's the lower radiator pipe.
http://cgi.ebay.com/ebaymotors/ws/eB...929432692&rd=1
Old Oct 21, 2004 | 07:13 AM
DanZ32's Avatar
Dan's the Man
You giving me a hard time?
I'm 39. As for Stewie and Brian....that has nothing to do with lack of age....lack of maturity on the other hand (It wouldn't be the first time someone has labelled me that way).
I don't think I will ever really grow up.
Beer Mmmmmmmmmmmmmmm
Old Oct 21, 2004 | 07:25 AM
tnkrstoyco's Avatar
Loves Going Topless
Don't feel bad Dan, my X said I'd never grow up as long as I still listened to Rock n Roll and I told her if listening to that boot scootin belly rubbin Country crap she listened to was grown up, I didn't care if I ever grew up.
Go for the Gold, Cuervo Gold that is.
Old Oct 21, 2004 | 07:42 AM
DanZ32's Avatar
Dan's the Man
Cheers!!!!
Remember..."it's better to burn out than fade away"
That has to be one of the most widely used lines in Rock and Roll...and it's oh so true
Old Oct 21, 2004 | 08:26 AM
91zxtt's Avatar
Not even a little bit. I think most of us will wind up in the same boat as you.....we may grow old, but we won't grow up.
Old Oct 21, 2004 | 08:53 AM
Jack Of All Trades
I hear the same stuff when my wife wakes me up in the shower or when I'm asleep in my car in the driveway after a nite on the town...............
Old Oct 21, 2004 | 10:38 AM
bardabe's Avatar
Bad Speller
I know I will never grow up either. I might get old and fart out dust. but I will still be a little child. When I was little I had a shirt that my brother bought me, it said, "F**k cookies and milk, I want ******* and beer!" ( . Y . )
