How do I get to the Horns.
Old Jan 10, 2008 | 10:58 AM
Darkmann's Avatar
I want to change mine to something more aligned with the car. Thanks.
Old Jan 10, 2008 | 11:21 AM
b300z's Avatar
caught the z fever
i believe theyre behind the bumper
Old Jan 10, 2008 | 01:15 PM
Darkmann's Avatar
I assume the bumper doesn't have to come off to access the horns. Do you know if the plastic wheel well trim has to come out, or the underside plastic protector? In my Z31, all I do is go under the car ahead of the front wheels and there they are. Thanks.
Old Jan 11, 2008 | 01:38 PM
MikeZ's Avatar
they sit like 6 inches in front of the radiator, right below the intake piping, near the gills for the intercoolers(for you) on both left and right side of nose.
Old Jan 11, 2008 | 05:50 PM
Darkmann's Avatar
Thanks Mike. I will pull out the engine plastic undercover and browse.
Old Jan 12, 2008 | 09:08 AM
ZLover4Life's Avatar
Encyclopedic Knowledge
Are you afraid of removing the fascia or something? It'd be SO much easier to approach it that way rather than maneuvering from under the car.
There's a writeup on how to remove in on tt.net. It won't take more than 20 minutes to figure out.
Old Jan 12, 2008 | 11:13 AM
its really easy to remove. especially if its been taken off before. i remember finding that write-up and there were only 2 bolts that were stupid hard to remove and impossible to re-install so if its been off once before, they should still be off. dont sweat it.
here you go: http://twinturbo.net/ttnetfaq/FAQpag...iaremoval.html
and here is the god of all Z problems and questions its SICK
http://twinturbo.net/ttnetfaq/z32faq.aspx
its almost has EVERY answer for EVERY question you could have on how do i....
Old Jan 12, 2008 | 12:22 PM
That's the writeup I was referring to. And as for the FAQ having almost every answer... the ones it doesn't have are usually found in Auto-FAQ.
Old Jan 12, 2008 | 01:37 PM
Darkmann's Avatar
Thanks all. I just figured it'd be easier to just leave the front facia alone. But I will check the write-up.
