HICAS Fluid
Old Apr 6, 2006 | 12:41 AM
beez's Avatar
HICAS Fluid
Hi,I'm the proud new owner of a 300zx twin turbo 2+2
What I want to ask however is my HICAS seems to be very low in fluids after driving quite a distance to fetch the car so i'm guessing it has a leak.
I'll fix that ASAP but would me driving the car with the warning light on and low in fluids for quite some time cause any damage?
Also in some 300zx FAQ's they say you should use Power steering fluid and then others say no you must definitly use Automatic transmission fluid.
Which one is it? and does it change the answer for which year the car is? and what region the car is from? or do all 300zx's across the board use one or the other?
Thanks alot
Beez
Old Apr 6, 2006 | 02:05 AM
entropy31's Avatar
The Cake Is A Lie!
this is a case of RTFM. owners manual says use Dexron ATF. dont use a "power steering fluid". nissan designed the car to use ATF. that is all you should use.
Old Apr 6, 2006 | 02:20 AM
beez's Avatar
Just saw that a little earlier,I should have RTFM thanks for the reply though.
beez
Old Apr 6, 2006 | 02:24 AM
entropy31's Avatar
The Cake Is A Lie!
no problem.
Rupe
Dec 4, 2011 11:28 AM
thxone
Nov 19, 2006 09:33 AM
burlz33
Oct 1, 2005 10:27 PM
nis88300zx
Sep 14, 2005 09:54 PM
tt300z
15
Jan 10, 2005 12:02 AM
