Hicas
Old Oct 1, 2005 | 07:44 AM
burlz33's Avatar
Hicas
I have a Z31 and just got a Z32 300zxTT. I'm not too familiar with the HICAS rear stearing. Can someone help me out on this? What does it stand for and how does it work/
Old Oct 1, 2005 | 08:26 AM
bardabe's Avatar
Bad Speller
I'm not sirewhat it stands for. but i believe it is.
High Inteligence C Asistant Steering.
and what it basically does. is after a sertain speed when you turn the shee. the back tires also turn. so teh car can switchlanes, or turn much faster, easier, and eficient.
Old Oct 1, 2005 | 08:57 AM
emo236's Avatar
confuzed member
ok, you were definitely way off on what it stands for bardabe.
This is what it actually stands for: High Capacity Actively Controlled Suspension (don't ask me how they figured "hicas" to stand for all that). It's a fancy way to say 4-wheel steering. At certain speeds (like bardabe said), it will turn your back wheels slightly.
Old Oct 1, 2005 | 10:23 AM
burlz33's Avatar
thanks
Thanks for the info. Does any one know if the Mustang Cobra SVT Five star wheels will fit 300ZXTT? The lug pattern matches, but will the points clear the brake calipers without spacers.
Old Oct 1, 2005 | 11:42 AM
emo236's Avatar
confuzed member
People have used cobra wheels before if that's what you're talking about. They fit fine, the problem with them is that the hub-centric bore (hub mounting ring thing) is too big. You can have a machine shop make you some though without any problems.
Old Oct 1, 2005 | 09:47 PM
MadZ420's Avatar
Hey, my HICAS light flickering on and off. It stays when cold. and when warm it comes on at high rpm. Any ideas about that this?
Old Oct 1, 2005 | 10:27 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
check your fluid level. If low, fill it with ATF Dexron III only (no, the power steering system on the Z32 does NOT take power steering fluid)
Rupe
Dec 4, 2011 11:28 AM
nis88300zx
Sep 14, 2005 09:54 PM
tt300z
15
Jan 10, 2005 12:02 AM
serg92
Sep 5, 2002 02:02 PM
SignalZ
Mar 7, 2002 09:25 PM
