gasoline smell. need help.
this morning when i turned on my heater, it smelled like gasoline for just a second. then i had to turn on the A/C with the heat to defrost my windows, and the gasoline smell got very strong. since that, the gasoline smell only comes when i use the A/C, and not the heat. anyone have any ideas why this is happening? i'm not leaking gas, that i know of, and all other fluid levels are fine. help - i can't stand the buzz i'm getting from the fumes.
Re: gasoline smell. need help.
Actually, you are leaking gas.... It is very common with Zs. Here ya go.....
Finding and Fixing Fuelleaks |
whoa. sounds like i've got a little work to do. thanks for the help.
my fuel lines seem to come loose every time the seasons change. Dunno why! It's not that hard to go thru & check all the clamps.
| All times are GMT -7. The time now is 12:32 AM. |
