Full VG re-build!
Old Aug 18, 2014 | 06:30 AM
zedhed300's Avatar
Full VG re-build!
this has probally been asked a million times before, but could someone please point me in the right direction for a full engine re-build walkthrough pretty much! on the net somewhere?! :S i know ive seen a couple ages ago, i think it had pics and was a walkthrough from starting at the bottom end right the way to droppin the engine in, i have to rebuild my engine next month and it would just be nice to have a bit of extra info, ive done it before, but it was a long time ago and im bound to forget bits! :s i have the full manual aswell to help!
cheers!
Old Aug 18, 2014 | 08:16 AM
cheers!
The manual has a full "walk through". If you've never rebuilt an engine before, I suggest you have an experienced mechanic with you. If you've done engine rebuilds before, just follow the FSM and you will be fine.
Old Aug 19, 2014 | 04:53 AM
zedhed300's Avatar
ive kindaaaaa rebuilt an engine before key points, make sure everythings very lubed up for first start up, liquid gasket everything execessivly and use correct torque settings CANT GO WRONG, na but it seriousness the only bit thats gona be tricky is the timing belt and parts installation, obviously i just make sure that cylinder one is at TDC when i put the belt on, i was thinking though, what about the cams?they could be tricky.
blue77z
Jan 2, 2012 09:45 AM
WildmaN
Dec 21, 2010 11:19 PM
Carl's Z
Aug 12, 2006 02:46 PM
RodMoyes
May 10, 2006 10:23 PM
DanZ32
Dec 19, 2004 09:04 PM
