engine swap or front clip n/a to Tt
just wanna hear some opinions and tell me what i'm missing, i'm wanting to swap a tt in my n/a, i've been researching parts heres what i got for the swap
Engine purchase jdm online, comes with trans,ecu,wiring harness and includes: Complete Motor - Block - Head - Intake Manifold - Exhaust Manifold - Sensors - Fuel Rail - Injectors - Cam Angle Sensor - Throttle Body - Alternator - Starter - Ignition Wires - Pulleys - Turbo manifold - Turbochargers I've researched buying these to complete the job: motor mount brackets Z1 motor mounts Z1 intercoolers used stock downpipes Z1 Mishimoto TT radiator radiator mounts Z1 silicone intercooler tubing New drive belt set 99' JSPEC front fascia gasket kit TT oil cooler boost gauge dual gauge pod pillar fuel pressure gauge lower radiator conversion bracket radiator bushings radiator hose set Z1 2.5"TT test pipes HKS Hi power cat back, dual New optima battery tt ac condensor Walbro fuel pump tt oil tree and i know i'm gonna need oil lines,vaccum lines, and such but i'm thinking alot of that comes with the engine and i'll have to buy some here and there. along with some other misc. things but is there anything i'm missing??? would love to hear some input. Thanks and in your opinion should i go this route, or go the front clip route?? |
Just buy a TT. Its cheaper lol.
TT swaps are only really recommended on great condition NA's... so unless your NA is really nice, just buy a TT.
With that said, get a front clip... buying all the little parts are going to nickel and dime you... badly. |
Don't forget
New Oil pump
New Oil Pan (it is usually crushed during shipping) EGR bypass Transmission/alternator harness Pretty much every hose/line on the engine will need to be replaced. 60k kit (timing belt and water pump) 6 new spark plugs the "long" oil lines (go from oil pan to cooler) Pressure sending unit AIC valve + assorted hose kit for it The JDM engine you get will be an automatic, are you planning to upgrade turbos while the engine is out? Front clip is the way to go. It's still a lot of work, I mean seriously, a lot of work. Everything is dirty and brittle and every piece of plastic will break or crack, every hose will snap when you take it off and all the wire harness connections will snap when you take them off. Better idea is to buy a nice TT:038: |
Thanks for all the input, i am a decent mechanic but sounds, like headaches to me, maybe i'll use the 9 thousand i'm gonna have save a little more and sell my n/a to buy a decent TT. I appreciate it y'all
