Engine Not Starting
Old Jul 28, 2010 | 12:22 PM
islandtuner242's Avatar
Engine Not Starting
ok so i finally finished buying my 1st dream tuner and the engine isn't starting (i knew this from i was purchasing the car).......so i wanted to know a couple of possibilities that may cause this, i think i've read before that draining the oil and the other fluids and the gas tank then putting new fluids back in should help..... keep in mind the car was just sitting in the guys driveway for about 2 years
Old Jul 28, 2010 | 12:36 PM
A motor needs 3 things to start:
-proper air
-proper fuel
-proper spark
Have you checked fuel pressure & that the injectors are spraying?
Have you checked spark?
Old Aug 17, 2010 | 06:16 PM
xxVERITASxx's Avatar
Well if he doesn't want to respond, maybe you can help me out Nismo. My '86 NA and I were cruising just fine - although it had serious troubles starting, like grinding noises - and then it simply died on me. I don't recall hearing anything break or explode or snap or whatever, it just lost power. I replaced the starter and no it cranks without grinding which is good, but it will not start! I don't have spark. Coil and ICM seem to be functioning from the 12-volt light tests I did. Thinking it's the crank angle sensor or entire distributor. Any suggestions?
Old Aug 17, 2010 | 07:08 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
86 NA put sit in the realm of Z31. This is the Z32 forum - you won't get much traffic here. Post in the Z31 forums for people familiar with Z31s.
Old Aug 18, 2010 | 05:08 PM
sorry i took so long to respond i sold my laptop and my desktop runs like crap....... now i haven't gotten a chance to look under the hood of the car since my new job has me tied up working 12 hour shifts but i plan to make time for this saturday to put in some wrench time, and btw how would i be able to check the fuel pressure?
Old Aug 18, 2010 | 05:17 PM
You would search this forum for "test fuel pressure," because I've written details on how to do it at least 4 times.
Old Aug 19, 2010 | 03:19 PM
i can't find it....think you could send me link?
Old Aug 19, 2010 | 04:19 PM
You should really hone your searching skills... the thread was even titled "fuel pressure"
Connect an in-line fuel pressure gauge and start the car. If the fuel pressure is not ~44psi at idle (and doesn't fluctuate directly with vacuum - at WOT, the gauge should read ~60psi), and/or if you turn the car off and the pressure drops to 0, the FPR is bad. If the needle vibrates badly, the damper is bad. Diagnosing fuel pressure problems is that simple.
Old Aug 23, 2010 | 10:21 AM
Lanoi's Avatar
1st Search
2nd Search
3.rd Get answers from us
Old Aug 23, 2010 | 02:07 PM
hmmm... there is no "us" in "Randy"... weird.
j/p
Old Aug 23, 2010 | 05:20 PM
Lanoi's Avatar
"randy" ???
Old Aug 23, 2010 | 10:47 PM
... that's my name...
... and I'm usually the ones with the answers...
Old Aug 24, 2010 | 08:12 AM
lulz.
Greg79
Apr 4, 2011 09:19 AM
fawx
Feb 16, 2010 11:46 AM
redlined280
Aug 31, 2006 10:04 PM
ZinAustin
Nov 1, 2002 07:58 AM
driccio2
Oct 29, 2002 04:20 PM
