Engine Check Light On?
Old Aug 13, 2008 | 10:30 AM
3riCJbOi's Avatar
one sound fits all
Engine Check light was on when i was driving
sooo i check ECU Codes and the code was 55 which mean there nothing wrong with it right?
but why would the engine check light go on but the ECU says theres nothing wrong man im confused
I am positive the codes said 55 i check a few times to be sure of it
any advise ppl
Old Aug 13, 2008 | 07:12 PM
KasbeKZ's Avatar
Pr0n Addict
it prob. doesn't make any difference, but which way did you check? bridging the wires in the diagnostics harness under the drivers side dash, or using the screw on the ecu?
sounds like a malfunctioning light to me. or a bad ECU
Old Aug 13, 2008 | 08:01 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
It could be an intermittent code... was the light still on when you checked the code?
Old Aug 14, 2008 | 12:25 AM
3riCJbOi's Avatar
one sound fits all
i used the screw and no the was not on when i check
the light was on last night when i was driving soo i checked this morning and the ecu code said there nothing wrong
the light was not on when i checked
Old Aug 14, 2008 | 01:00 AM
Niku-Sama's Avatar
eff good grammar
do these do the "at a certian milage take in for service because the check engine light is on" thing like some of the cars from the mid to late 80's did?
Old Aug 14, 2008 | 01:17 AM
No, the only reason the check engine light would come on is if there was an error code.
And if the check engine light was not on when you checked it, then there was no error code to pull and that's why you got 55. The ECU thought the problem was fixed (or perhaps it was a loose wire that reconnected).
Old Aug 14, 2008 | 03:22 PM
3riCJbOi's Avatar
one sound fits all
well i guess so
it didnt come on today but i should be more attention just in case it goes on again so i can check the ECU code on the spot to see whats wrong
well anyways thanks for the info
ill keep an eye out for it
oO yeah thanks alot Zlover4life you were alot of help really thanks man i really appreciated
Old Aug 14, 2008 | 07:24 PM
KasbeKZ's Avatar
Pr0n Addict
for checking on the spot you should look up which slots on that harness to bridge so that you don't need to pull up the floorboard if you don't have time. you just stick a wire in and look at the check engine light
Old Aug 20, 2008 | 09:01 PM
3riCJbOi's Avatar
one sound fits all
I finally got a code reading out
the ECU code reads 32
EGR Malfunction Detected
is this serious?
it doesnt seem to be affecting my car's performance
soo i dont know whats up
any info would help alot
Old Aug 20, 2008 | 09:03 PM
Maybe check the EGR...
Old Aug 20, 2008 | 09:08 PM
3riCJbOi's Avatar
one sound fits all
Like can any problem come from the EGR System malfunctioning ?
I wanna know how serious can this problem be
so i would know what im dealing with here
Old Aug 20, 2008 | 09:16 PM
http://www.300zx.co.uk/cgi-bin/manual.cgi
JoseRobles
May 12, 2015 07:39 AM
drifto
Sep 21, 2012 12:37 PM
Z-man91
Apr 20, 2010 06:56 PM
fozs00
Apr 25, 2005 11:54 AM
speedracer1
Nov 18, 2002 09:50 PM
