ZDriver.com
-   300ZX (Z32) Forums (https://www.zdriver.com/forums/300zx-z32-forums-7/)
-   -   Engine Check Light On? (https://www.zdriver.com/forums/300zx-z32-forums-7/engine-check-light-26414/)
3riCJbOi Aug 13, 2008 10:30 AM
Engine Check light was on when i was driving
sooo i check ECU Codes and the code was 55 which mean there nothing wrong with it right?
but why would the engine check light go on but the ECU says theres nothing wrong man im confused
I am positive the codes said 55 i check a few times to be sure of it
any advise ppl
KasbeKZ Aug 13, 2008 07:12 PM
it prob. doesn't make any difference, but which way did you check? bridging the wires in the diagnostics harness under the drivers side dash, or using the screw on the ecu?
sounds like a malfunctioning light to me. or a bad ECU
ZLover4Life Aug 13, 2008 08:01 PM
It could be an intermittent code... was the light still on when you checked the code?
3riCJbOi Aug 14, 2008 12:25 AM
i used the screw and no the was not on when i check
the light was on last night when i was driving soo i checked this morning and the ecu code said there nothing wrong
the light was not on when i checked
Niku-Sama Aug 14, 2008 01:00 AM
do these do the "at a certian milage take in for service because the check engine light is on" thing like some of the cars from the mid to late 80's did?
ZLover4Life Aug 14, 2008 01:17 AM
No, the only reason the check engine light would come on is if there was an error code.
And if the check engine light was not on when you checked it, then there was no error code to pull and that's why you got 55. The ECU thought the problem was fixed (or perhaps it was a loose wire that reconnected).
3riCJbOi Aug 14, 2008 03:22 PM
well i guess so
it didnt come on today but i should be more attention just in case it goes on again so i can check the ECU code on the spot to see whats wrong
well anyways thanks for the info
ill keep an eye out for it
oO yeah thanks alot Zlover4life you were alot of help really thanks man i really appreciated
KasbeKZ Aug 14, 2008 07:24 PM
for checking on the spot you should look up which slots on that harness to bridge so that you don't need to pull up the floorboard if you don't have time. you just stick a wire in and look at the check engine light
3riCJbOi Aug 20, 2008 09:01 PM
I finally got a code reading out
the ECU code reads 32
EGR Malfunction Detected
is this serious?
it doesnt seem to be affecting my car's performance
soo i dont know whats up
any info would help alot
NismoPick Aug 20, 2008 09:03 PM
Maybe check the EGR... :D
3riCJbOi Aug 20, 2008 09:08 PM
Like can any problem come from the EGR System malfunctioning ?
I wanna know how serious can this problem be
so i would know what im dealing with here
NismoPick Aug 20, 2008 09:16 PM
http://www.300zx.co.uk/cgi-bin/manual.cgi
http://www.300zx.co.uk/tech/manual/manual/efec/042.gif
http://www.300zx.co.uk/tech/manual/manual/efec/124.gif
