definatly need suggestions fast
Old Jan 18, 2006 | 03:52 PM
well...i need to change my injectors, theres a shop here in chicago that will do it, so i decide to get the drivers side injectors out for now save some money becuase its the only side that has ever given my trouble. i start taking out bolts and crap get every thing out that i thought i needed to to take off the intake maniflod and that thing is still rock solid on there. i noticed underneath each side of the intak manifold is a pipe bolted on and also 2 other bolts on the side. dotn know how i can get those off or if they even need to. so i was wondering if any of you have done this(im sure someone has) and if so how you did it. or if anyone can point me to a write up with mabye like pictures or soemthign i dotn know. but im a bit lost.and kinda really wanna get my Z runing again. im trying to avoid the shop time of 4 hours at 88 dollars and hour if possible but as of right now thats what it looks like ill be doing. which sucks. so yeah HELP!!!! FAST!!!
Old Jan 18, 2006 | 04:18 PM
ok i searched around and foun where this was already sorta posted and then this awsome link to twinturbo.net and saw everything...and that upper intake plenum is gonna be a bi*** like i thought. and what i thought i missed seems to be the only 8 bolts i did miss. its those stupid egr pipes underneath both side of the intake adn the 2 bolts on each side of the intake right by those EGR pipes. this kinda really sux. i also see some bolts i took off that i didnt need to. oops. no bid they are easy to put back on. hopefully thats all i need till i can just pop the intake plenum on. im still open to suggestions on what mabye soem of you have done in the past to make the job a little easier that what this site says http://www.twinturbo.net/ttnettech/plenum/plenum.aspx
Old Jan 18, 2006 | 07:17 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
get 45degree angled mini-vice-grips and you can do it without grinding away at the plenum. Use the vice-grips to remove the screws you can't reach, and use pliers to pull out the injectors.
Old Jan 19, 2006 | 01:19 AM
Riz Z Speed's Avatar
Administrative Brown Guy
keep track of what goes where and you shouldn't have any problems.
Those hose clamps tend to try your patience some. If you can try the angled vice grips route, i'd recommend it. Makes the job much much easier.
Old Jan 19, 2006 | 10:14 PM
thanks guys. if i ever need to do that ill do it. i busted up soem good knuckles for nothing. im dumb and forgot to pull the connectors on the plugs and scrape the leeds inside wiht a small ex-acto knife, yeha it works again. stupid corrosion.
Old Jan 20, 2006 | 09:15 AM
I'm glad for you it was an easy solution... injectors are fun the first time
Old Jan 21, 2006 | 07:16 PM
hey ive been told of the dremel method...any reason i shouldnt do that if i have to besides obviously im gonna have grind marks on my plenum? like anything that could be bad?
Old Jan 21, 2006 | 10:33 PM
umm... yeah.... on a cold day, your plenum cracks because there isn't enough material to maintain structural integrity
like I said, get 45degree vice grips and you can get those screws without grinding...
Old Jan 24, 2006 | 01:07 PM
ahh..thats a good reason for us chicago people. yet another reason i hate the cold. the dremel idea sounded to good to be true.....
Old Jan 24, 2006 | 06:03 PM
CanyonCarver's Avatar
Jack Of All Trades
That is funny. Your plenum will not crack due to the cold, because you dremeled out some material to get a screwdriver to an injector screw. I wish I had the ROFL emoticon.
Old Jan 25, 2006 | 06:21 PM
ahhh..now i dotn know who to trust..... my intelect is being challenged so badly. i need scientific evidence now.
91Zman
Other Cars
17
Nov 21, 2005 07:46 AM
The_280z_man
Jul 23, 2003 11:52 PM
brianglawson
Jun 22, 2003 10:04 PM
brianglawson
Jun 18, 2003 08:08 PM
WANTED300zx
Oct 20, 2002 03:14 PM
