Thomas Ward |
06-10-2014 10:53 AM |
91TT Problems HELP Please
OK so to start with I was coming home after working a 24 hour Staff duty shift and my z just stalls out like I ran out of gas (Still have a quarter tank of gas). I was a little suspect about the injectors before this happened so I got it towed home and ohm'd out the injectors. 4 or the 6 ohm'd out bad. So online shopping I went. I replaced all of the injectors with the new style injectors and tried to start it up and nothing... No change at all. So I checked the input side of the fuel filter and I have no fuel pressure. So I start by checking all of my fuses and relays. All seem to be good. I then check to see if I have power at the connector at the fuel pump and I do. So I order a new fuel pump. Install and crank..... No change. So now about $1300 in on this repair and still no running car. I then pull the the rug to check the diagnostics on the ecu. Turn the key to ACC and no LED on the ECU. I pull the plug on the ECU and have power on pins 49 58 and 59...but no LED. I try resetting and removing the Anti theft to see if that is the cause but no change in the symptoms. Please help before my wife leaves me lol.... but seriously I really need this car to be running soon before my wife's classes start back up.
