93Z has power, but won't start
Old 07-01-2013, 05:55 PM
PresidentDion's Avatar
I have a '93 Z32 which was running fine until just the other day. Now it wont start. Everything turns on and the car has full power, but just won't start. I replaced the starter, ignition switch and battery. I'm out of ideas. Anyone know what's up?
PresidentDion is offline
Old 07-01-2013, 07:54 PM
Horsepower Mathematician
Rupe's Avatar
You mention everything turns on but does it crank when you try to start it?
Rupe is offline
Old 07-01-2013, 09:38 PM
Nope - no cranking or clicking.
Old 07-05-2013, 07:32 PM
93z32txk's Avatar
is your fuel pump kicking on
93z32txk is offline
Old 07-05-2013, 11:08 PM
Fourplants's Avatar
are you pushing in the clutch?
Fourplants is offline
Old 07-27-2013, 10:24 AM
Virtuoso's Avatar
Z32 Non-Start (Nothing Happens?)
https://www.linkedin.com/feed/update...1581116153856/After much diagnostic activity the solution finally jumped out; a $3.30 ("cough drop") clutch pedal stop from Nissan...you can see where it goes by looking up the pedal arm and finding a circular opening in the "holding bracket" (my term...it is shown but not called out in the FSM)...without taking anything apart...what this plastic part does is depress the safety switch, allowing current to flow to the relay...hence the starter motor..you have probably seen pieces of green plastic lying on the floor mat under your clutch pedal...a tip-off is the manual does not show any adjustment numbers for the clutch pedal.
08.02.2018_saw more green plastic under the clutch pedal, went to Nissan wholesale parts; now this same plastic button was $14.00 (after shop discount)
(these cars must have two of these, cause the previous one is still good)
Virtuoso is offline
Old 08-14-2017, 08:29 AM
Virtuoso's Avatar
1993 Z32 Non-Starting
Originally Posted by virtuoso
after much diagnostic activity the solution finally jumped out; a $3.30 ("cough drop") clutch pedal stop from nissan...you can see where it goes by looking up the pedal arm and finding a circular opening in the "holding bracket" (my term...it is shown but not called out in the fsm)...without taking anything apart...what this plastic part does is depress the safety switch, allowing current to flow to the relay...hence the starter motor..you have probably seen pieces of green plastic lying on the floor mat under your clutch pedal...a tip-off is the manual does not show any adjustment numbers for the clutch pedal.
Virtuoso is offline
Old 08-14-2017, 08:32 AM
Virtuoso's Avatar
Hi, see my reply to this thread..seems like the very same symptoms mine was exhibiting.
Virtuoso is offline
Old 01-16-2018, 12:39 PM
Young.gio's Avatar
I had the same problem about 3 months ago. Try changing the starter relay. It is located in the wheel well of the front driver side tire. Worked for me! Goodluck!
Young.gio is offline
bongpogi
08-19-2015 11:15 AM
pizza914
03-02-2013 06:46 PM
moorebl
04-14-2011 03:28 PM
L4ugh1ngM4n
10-21-2009 05:53 AM
Quick Reply: 93Z has power, but won't start
