Rear Rotors Won't Come Off..
Old Jan 19, 2012 | 07:54 AM
NSFR's Avatar
So I thought the rear rotors would come off as easy as the Front rotors on a z32... I was hella wrong.. Can someone give me a sure fire way of getting these Danged rotors off?!?
Thanks in Advanced..
Edited*
BUMP.. People say Google saves lives.. Lol I'm such a Dweeb.. for all those who are reading this and have the same question.... this is how its done..
1. release your e-brake
2. find a bolt to fit in the little threaded hole near the hub on the face of the rotor
3. slowly screw it in and you will see the rotor move a little, if you have two holes on opposite sides switch between sides, screwing until the rotor moves toward you little by little, eventually it will pop and there goes the weasel.
Your basically using the bolt to press the rotor off, against the hub.
Special thanks to NolimitZ32 over at NicoClub..
as I said Google Saves Lives!!
Old Jan 23, 2012 | 06:45 PM
1QIKZ's Avatar
If I'm not mistaken, the parking brake pad will hang up on the inner surface of the drum portion of the rotor. Release the brake and back off the tension if you need to. Penetrating oil on the hub would probably help.
Old Jan 24, 2012 | 12:09 AM
Rupe's Avatar
Horsepower Mathematician
Pretty sure he figured that one out already :P
Old Jan 28, 2012 | 08:40 AM
NSFR's Avatar
In Deed I did, pretty much the same day I posted this.. but thanks for the response!!
mrprofile
Apr 5, 2011 11:34 AM
jrealmuto1
Apr 14, 2009 04:27 PM
znasty1
May 15, 2005 11:06 PM
CanyonCarver
FS: 300ZX (90-96)
May 9, 2005 06:43 PM
znasty1
FS: 300ZX (84-89)
Apr 4, 2005 01:57 PM
